Aggiornamento: System SpecGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.65![]() Aggiornamento dalla versione 2.63 alla 2.65 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Anche questa nuova versione sul mio computer non parte. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Rcs wrote ... Risultato test: Anche questa nuova versione sul mio computer non parte. Idem, zero assoluto! | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.75 Link winPenPack Aggiornamento dalla versione 2.65 alla 2.75 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.78 Link winPenPack Aggiornamento dalla versione 2.75 alla 2.78 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Tue 14 Sep 2010 - 15:53 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.84 Link winPenPack Aggiornamento dalla versione 2.78 alla 2.84 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Thu 25 Nov 2010 - 19:58 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.87 Link winPenPack Aggiornamento dalla versione 2.84 alla 2.87 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.88 Link winPenPack Aggiornamento dalla versione 2.87 alla 2.88 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.90 Link winPenPack Aggiornamento dalla versione 2.88 alla 2.90 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.91 Link winPenPack Aggiornamento dalla versione 2.90 alla 2.91 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | System Spec 2.96 Link winPenPack Aggiornamento dalla versione 2.91 alla 2.96 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Fri 01 Jul 2011 - 23:29 ] | ||
