Aggiornamento: X-ScribusGo to page >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | X-Scribus 1.3.3.10 Link winPenPack Aggiornamento dalla versione 1.3.3.9 alla 1.3.3.10 Home: -Link- ![]() Direct link: not portable -Link- ![]() [ Edited Sat 18 Sep 2010 - 19:43 ] | ||
| alchimista |
![]() ![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | X-Scribus 1.3.3.11![]() Aggiornamento dalla versione 1.3.3.10 alla 1.3.3.11 Home: -Link- ![]() Direct link: not portable -Link- ![]() [ Edited Tue 15 Jan 2008 - 20:32 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | X-Scribus 1.3.3.12 Link winPenPack Aggiornamento dalla versione 1.3.3.11 alla 1.3.3.12 Home: -Link- ![]() Direct link: not portable -Link- ![]() [ Edited Sun 22 Jun 2008 - 20:03 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | X-Scribus 1.3.3.13 Link winPenPack Aggiornamento dalla versione 1.3.3.12 alla 1.3.3.13 Home: -Link- ![]() Direct link: (not portable) -Link- ![]() [ Edited Sat 25 Apr 2009 - 20:41 ] | ||
| sceicco |
![]() ![]() Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 244 | X-Scribus 1.3.5.1 Link winPenPack Aggiornamento dalla versione 1.3.3.11 alla 1.3.5.1 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() Edit by Danix: la 1.3.5.1 è una versione di sviluppo (infatti si trova in "scribus-devel"). L'ultima stabile è la 1.3.3.13 [ Edited Tue 18 Aug 2009 - 01:03 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | X-Scribus 1.3.3.14 Link winPenPack Aggiornamento dalla versione 1.3.3.13 alla 1.3.3.14 Home: -Link- ![]() Direct link: (not portable) -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | X-Scribus 1.3.8 Link winPenPack Aggiornamento dalla versione 1.3.3.14 alla 1.3.8 Home: -Link- ![]() Direct link: (not portable) -Link- ![]() [ Edited Sat 18 Sep 2010 - 19:39 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12447 ![]() | Rcs wrote ... Aggiornamento dalla versione 1.3.3.14 alla 1.3.8 La versione 1.3.8 è una versione di sviluppo (non compatibile con l'attuale launcher), mentre l'ultima stabile è la 1.3.3.14. Direi di non aggiornare la versione in download, almeno per ora. Comunicazione di servizio: nelle nuove versioni la variabile %HOME% non funziona, quindi il profilo viene creato in %AppData%. Dobbiamo verificare se nella documentazione si fa riferimento a una nuova variabile per redirigere il profilo in \User [ Edited Sat 18 Sep 2010 - 19:53 ] | ||
| vix |
![]() ![]() Registered Member #11044 Joined: Sat 10 May 2008 - 15:17Posts: 27 | Comunicazione di servizio: nelle nuove versioni la variabile %HOME% non funziona, quindi il profilo viene creato in %AppData%. Dobbiamo verificare se nella documentazione si fa riferimento a una nuova variabile per redirigere il profilo in \User Ho controllato nella documentazione di Scribus: a partire dalla versione 1.3.4 il profilo viene salvato nella "Application Data" dell'utente attivo, invece che nella %HOME%. Alcuni utenti hanno già segnalato questa differenza, ma gli sviluppatori hanno confermato essere una modifica voluta, nella migrazione da Qt3 a Qt4, per superare alcuni limiti delle variabili d'ambiente. Siccome "Aplication Data" è una sottocartella di "User", forse potrebbe essere possibile reindirizzare tutta la cartella utente, ma non saprei. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12447 ![]() | ================================================== ================================================== X-Scribus 1.4.0 RC5 Link winPenPack Aggiornamento dalla versione 1.3.3.14 alla 1.4.0 RC5 Home: -Link- ![]() Direct link: (not portable) -Link- ![]() | ||
