Aggiornamento: X-StellariumGo to page >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Stellarium 0.9.1 Link winPenPack Aggiornamento dalla versione 0.9.0 alla 0.9.1 Home: -Link- ![]() Direct link: -Link- ![]() [ Edited Fri 18 Jan 2008 - 14:52 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Stellarium 0.10.0 beta Link winPenPack Aggiornamento dalla versione 0.9.1 alla 0.10.0 beta Home: -Link- ![]() Direct link: -Link- ![]() [ Edited Mon 27 Oct 2008 - 15:07 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Stellarium 0.10.2 Link winPenPack Aggiornamento dalla versione 0.10.0 beta alla 0.10.2 Home: -Link- ![]() Direct link: -Link- ![]() [ Edited Fri 13 Mar 2009 - 20:44 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Stellarium 0.10.3 Link winPenPack Aggiornamento dalla versione 0.10.2 alla 0.10.3 Home: -Link- ![]() Direct link: -Link- ![]() [ Edited Mon 22 Feb 2010 - 15:52 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Stellarium 0.10.4 Link winPenPack Aggiornamento dalla versione 0.10.3 alla 0.10.4 Home: -Link- ![]() Direct link: -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Sun 28 Feb 2010 - 21:37 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | Con la nuova versione in download visualizzo i dati sulla sinistra in alto così:![]() Mentre nella versione precedente (0.10.2) li visualizzo correttamente: ![]() | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3145 ![]() | Con la versione aggiornata 0.10.4 io li visualizzavo correttamente, non mi si è presentato nessun problema. Danix, prova a verificare nel file log (in "home") se è riportato qualcosa... | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | Forse è un problema di utilizzo della memoria: log.zip | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3145 ![]() | Confermo: funziona correttamente sia su Xp SP3 che su Vista SP2, visualizzando correttamente i caratteri. | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Stellarium 0.10.5 Link winPenPack Aggiornamento dalla versione 0.10.4 alla 0.10.5 Home: -Link- ![]() Direct link: -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Thu 10 Jun 2010 - 22:44 ] | ||
