Aggiornamento: PDF-XChange Viewer Portable Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 1.034 Link winPenPack Aggiornamento dalla versione 1.033 alla 1.034 Home: -Link- Direct link: -Link- [ Edited Wed 08 Dec 2010 - 17:58 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.035 Link winPenPack Aggiornamento dalla versione 1.034 alla 2.035 Home: -Link- Direct link: -Link- Risultato test: Niente da segnalare [ Edited Sat 08 Mar 2008 - 09:28 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.036 Link winPenPack Aggiornamento dalla versione 2.035 alla 2.036 Home: -Link- Direct link: -Link- Risultato test: Niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.037 Link winPenPack Aggiornamento dalla versione 2.036 alla 2.037 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Thu 08 May 2008 - 20:58 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.0037.1 Link winPenPack Aggiornamento dalla versione 2.037 alla 2.0037.1 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Fri 16 May 2008 - 22:23 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.0037.2 Link winPenPack Aggiornamento dalla versione 2.0037.1 alla 2.0037.2 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Sat 17 May 2008 - 19:29 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.0038 Link winPenPack Aggiornamento dalla versione 2.0037.2 alla 2.0038 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.0038.2 Link winPenPack Aggiornamento dalla versione 2.0038 alla 2.0038.2 Home: -Link- Direct link: -Link- === EDIT by TAF === la versione in Download è la 2.0 Build 38.2 e non 39 come precedentemente citato (RCS, scusa per l'intromissione) - - - - - Edit Rcs - - - - Risultato test: niente da segnalare Grazie, TAF [ Edited Tue 22 Jul 2008 - 22:54 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable v.2.0039 Link winPenPack Aggiornamento dalla versione 2.0038.2 alla 2.0039 Home: -Link- Direct link: -Link- Risultato test: Non testato | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | L'ultima versione segnalata sembra avere dei problemi nel riconoscere i caratteri, vedi Screenshot allegato: [ Edited Sun 03 Aug 2008 - 23:20 ] | ||
