winPenPack Launcher - Russian translationGo to page >> |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | Official thread of winPenPack Launcher - Russian translation. Please, send your .xml file here. | ||
| Itar-Tass |
![]() ![]() Registered Member #13335 Joined: Thu 04 Sep 2008 - 13:58Posts: 1 | -link removed- [ Edited Thu 04 Sep 2008 - 17:15 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | Thank you, Itar-Tass, but the attached translation is not for winPenPack Launcher. Link removed. | ||
| svm |
![]() ![]() Registered Member #13704 Joined: Sat 20 Sep 2008 - 14:36Posts: 2 | Так будет русский язык или нет? | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | English please. | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 483 ![]() | @Danix, scusa se mi intrometto... il testo in cirillico dice: 'Cosi sarà la lingua russa o no?' credo che voglia sapere se il file di traduzione, per il russo, può essere scritto in cirillico. ciao | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | Grazie rbon, non sapevo che parlassi anche il cirillico! La traduzione russa è già inclusa nei wpp, se non ricordo male.. | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 483 ![]() | non sapevo che leggessi anche il cirillico! Non leggo il cirillico, ho solo usato:Google - Strumenti per le lingue - Traduci la pagina Web (il thread sul russo) - traduzione da Russo a Italiano ciao [ Edited Sun 21 Sep 2008 - 17:26 ] | ||
| svm |
![]() ![]() Registered Member #13704 Joined: Sat 20 Sep 2008 - 14:36Posts: 2 | Danix wrote ... English please. Ok: So will the Russian language, or not? | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12448 ![]() | The russian language is already present in wpp collections. You have not found it in winpenpack\user\winpenpack_launcher folder? If you think is not correct, or if you don't like it, please contribute translating the .xml file. | ||
