[Utility]UDPixel 2.2 (controllo pixel bruciati) |
| icemax |
![]() ![]() Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 ![]() | Nome Software:UDPixel Direct Link al download: -Link- ![]() Dimensione File: 156 KB (159,744) Nome autore: Samuel Larché eMail autore: -eMail- ![]() Sito Web Autore: -Link- ![]() Descrizione: Permette di controllare l'eventuale presenza dei "famosi" pixel bruciati negli schermi LCD. Portable tips how-to: Software NO-Install - scrive le proprie impostazioni sul file : udpixel.xml che verrà creato nella cartella contenitore. (* necessaria la presenza del .NET Framework v2) Versione:2.2 Licenza:Freeware Download - Pocket PC version smartUDPixel v0.2 English (.exe - 11kB) screenshot : info originali : Description: This program helps to locate and fix LCD screens dead pixels. You can fix the stuck pixels by calling them to do rapid changes. You need to run this program for a couple of hours. There is no warranty on the result, but you don't really have anything to lose trying it out. Good luck. Version: 2.2 Licence: Freeware Platform: Windows Vista/XP/2000 with .NET Framework v2 Author: Samuel Larché [ Edited Tue 11 Mar 2008 - 10:45 ] | ||
