[Network Utility] Vistumbler: WiFi & GPS scanner |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 |
Nome Software:Vistumbler Direct Link al download: -Link- Dimensione File: 1,02 MB (1.080.000) Nome autore: techidiots.net eMail autore: -Link- Sito Web Autore: -Link- Descrizione: Utility open source per lo scan di rete WI-FI e GPS netstumbler like compatibile esclusivamente con Windows VISTA. Supporto multilingua compreso l'ITALIANO. Portable tips how-to: Software installer - installare l programma normalmente, alla fine copiare in una cartella a piacere tutti i files escluso uninstall.exe , ed infine disinstallare il programma dal menu start. - Il programma scrive le proprie impostazioni nei files : mac_labels.ini, manufactures.ini, vistumbler_settings.ini all'interno della cartella settings. (* OS supportati : Solo Windows VISTA) (* SORGENTI scaricabili da QUI Vistumbler v7.42 source (Componenti richiesti per il GPS : Netcomm OCX da inserire nella cartella di Vistumbler) Versione:v7.42 Licenza:Open Source screenshot : info originali : Features Find Wireless access points - Uses the Vista command 'netsh wlan show networks mode=bssid' to get wireless information GPS Support Export/Import access points from txt file Export access point GPS locations to a Google Earth KML file Open Source ( AutoIt Scripting Language - -Link- ) Change column order, column title, and column width in the 'vistumbler_settings.ini' file Change search terms in the 'vistumbler_settings.ini' file. This means Vistumbler should be able to work with other languages. Change searchwords to what they are in the another language, Search terms can be found by running 'netsh wlan show networks mode=bssid' in a command prompt. GPS Info : To use GPS you can use 'CommMG' or 'Netcomm OCX'. 'CommMG' is included, but it is less stable. With 'CommMG' if you unplug the GPS without turning it off then Vistumbler will crash. 'Netcomm OCX' does not have this problem. To use 'Netcomm OCX' it first needs to be installed ( -Link- ). If you are using x64 vista, CommMG is your only option. Netcomm OCX is the recommended choice for GPS. [ Edited Tue 11 Mar 2008 - 19:27 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Nuova versione rilasciata. Direct Link al download exe: -Link- Nuovo sito: -Link- Versione: 9.0 (28.11.08) TEST:
Sposto in Richieste per verifica. [ Edited Thu 05 Feb 2009 - 22:23 ] | ||
