Programming Language |
| Peter G |
![]() ![]() Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | I would like to suggest: X-Python (--> -Link- ![]() and X-Ruby (www.ruby-lang.org) Both powerful and (more or less !?) easy-to-learn programming languages. It would be great to use that languages without the need of (hard) install an the PC | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi Peter G, thank you for your suggestions! At this moment we don'have such environments, but did you already seen 1) Portable Python -Link- ![]() 2) AllInOneRuby -Link- ?You are welcome to check if they fit your needs. Best Regards ZioZione [ Edited Wed 02 Apr 2008 - 12:25 ] | ||
