Piccoli ma utili programmi standalone [reti e sicurezza] |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | licenza per questi programmi : * This software may be distributed freely on online services, bulletin boards, or other electronic media as long as the files are distributed in their entirety. info -> SONO TUTTI STANDALONE Secrets Viewer 1.1 -Link- Secrets Viewer is a small utility that retrieves the passwords stored on your computer by Internet Explorer, Outlook Express and MSN Explorer IE History Monitor 2.1 History Monitor is a Windows program that will show you detailed listings of all visited Internet pages, including the captions, URLs, date of last access and expiration -Link- TCP Monitor 2.0 TCP Monitor is a Windows program that will show you detailed listings of all TCP endpoints on your system, including names of remote servers and state of TCP connections -Link- Ping Terminal 2.5 Ping Terminal allows the user to test the reachability of another host in the network. It gives information about the response time and the integrity of data sent, and to retrieve information about how IP packets -Link- bye | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Secrets Viewer NON portabilizzabili -Link- IE History Monitor non è portabile, nel registro aggiunge 2 chiavi Spoiler: e relativi valori TCP Monitor non è portabile, anche questo salva le impostazioni nel registro. Spoiler: e relativi valori Ping Terminal come i precedenti, not portable Spoiler: e relativi valori | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | icemax..... che ne avesse beccato uno! Son tutti freeware? [ Edited Sat 14 Feb 2009 - 15:43 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Spostato in "Software NON portabilizzabili" | ||
