applicazioni FREE&SOURCE leggerissime ma molto potenti
icemax
Sat 27 Jan 2007 - 15:51
Registered Member #194
ciao forum :
vi segnalo questo sito, troverete applicazioni FREEWARE leggerissime ma molto potenti
alcune delle quali accompagnate da codice sorgente :
il sito :
http://dukelupus.pri.ee/index.php
le applicazioni [ alcune da rendere portabili]
Ø AudioMagus
AudioMagus is a free program for sorting, renaming and tagging of audio files.Simple and intuitive interface,
supports mostl common audio types
(.AAC,.AC3,.APE,.AU,.DTS,.FLAC, .M4A, .M4B, .M4P,.MAC,.MP2,.MP3, .MPA,.MPC, .OFR,.OFS,.OGG,.TTA,
.VQF,.WAV,.WMA,.WV), FreeDB support (can query by both name and checksum), tag-to-name function
and much more.
Ø AutoRun
is very simple and basic application to create autorun menu for CD's or DVD's. You can change image,
icon, caption, number and function of buttons and their appearance. All changes are done by modifying
the ini file and are very easy to understand
Ø ConverLIT GUI
is a graphical user interface for the wonderful command-line tool convertlit . With ConvertLIT, you can extract files from Microsoft proprietary ebook format .lit (see -Link- for more
information), you can also downconvert (ie remove DRM protection) and inscribe lit files.
Ø DirLister
is an utility for listing directory contents.
It can be run from GUI or Windows Explorer shell right-click menu, output may be .txt or .html.
You can select recursive mode and file mask to use for listing. Also, you can include file sizes.
Ø IP2country
is a small application that takes an IP or host and tells you in which country the IP is located
Ø ScreenMagus is an easy to use screenshot utility -
can save images in .gif, .bmp, .png, .tiff and .jpeg format, minimizes to tray,
can take screenshots of both active window and whole desktop
Ø SimpleMAC - - - the best - - - -
is a simple and free utility for changing MAC address on Windows XP and Windows 2000.
It supports also changing MAC address from command line.
Also, on SimpleMAC page there is a small manual for MAC cloning.
Ø txt2html
is a program to convert plain text files to the hypertext markup language
Ø WinErrors
Small utility to search Windows error messages by error code. Also contains a list of
all Windows error messages.
Ø WordMagus
is a conversion utility that uses Microsoft Word as an engine. In addition to converting between Word
formats, WordMagus employs utilities to convert or decompile some other common document formats,
such as PDF, HLP, PRC/PDB, LIT and RB.
... molto utile e potente : SimpleMAC [per modificare l'indirizzo MAC di un adattatore di rete..utilissimo in molti casi]
tutte queste applicazioni possono girare su pen
a voi la parola
ciaooooooooooooooooooooooo
Sat 14 Feb 2009 - 16:26
Registered Member #5089
Non trovo un link per scaricarli e testarli, il sito segnalato non esiste più
Sat 14 Feb 2009 - 16:29
Ok, cestinato..
P.S. complimenti a icemax per il titolo "applicazioni FREE&SOURCE leggerissime ma molto potenti"
[ Edited Sat 14 Feb 2009 - 16:30 ]
Sat 14 Feb 2009 - 16:33
Registered Member #9897
Ketty wrote ...
Ciao a tutti, se può interessare, alcuni di quei programmi sono a questo -Link-
---edit---
come non detto, pensavo che i software fossero presenti in softpedia e non linkati al sito, pardon...
[ Edited Sat 14 Feb 2009 - 16:35 ]
Sì ma puntano allo stesso sito segnalato da Ice e non si scarica nulla, a meno che non sia troppo rimba oggi
Sat 14 Feb 2009 - 16:37
txt2html
Sat 14 Feb 2009 - 16:38
Ecco la pagina giusta -Link-
Sat 14 Feb 2009 - 16:43
Ecco allora sono proprio rimbambita
Sat 14 Feb 2009 - 16:46
Scusate, ma è proprio il principio secondo cui è stata fatta la segnalazione che non va bene.
Non è colpa di icemax, ma il problema sta proprio nella mancanza di linee guida all'epoca della segnalazione.
In questi casi, come dicevo a Ketty, o si analizza e si testa ogni singolo software segnalato, o si lascia perdere. E' un lavoraccio..
[ Edited Sat 14 Feb 2009 - 16:46 ]
Sat 14 Feb 2009 - 16:48
Ho segnalato la pagina credendo che Ketty voglia appunto testare i software.
