applicazioni FREE&SOURCE leggerissime ma molto potenti Go to page >> |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | ciao forum : vi segnalo questo sito, troverete applicazioni FREEWARE leggerissime ma molto potenti alcune delle quali accompagnate da codice sorgente : il sito : http://dukelupus.pri.ee/index.php le applicazioni [ alcune da rendere portabili] Ø AudioMagus AudioMagus is a free program for sorting, renaming and tagging of audio files.Simple and intuitive interface, supports mostl common audio types (.AAC,.AC3,.APE,.AU,.DTS,.FLAC, .M4A, .M4B, .M4P,.MAC,.MP2,.MP3, .MPA,.MPC, .OFR,.OFS,.OGG,.TTA, .VQF,.WAV,.WMA,.WV), FreeDB support (can query by both name and checksum), tag-to-name function and much more. Ø AutoRun is very simple and basic application to create autorun menu for CD's or DVD's. You can change image, icon, caption, number and function of buttons and their appearance. All changes are done by modifying the ini file and are very easy to understand Ø ConverLIT GUI is a graphical user interface for the wonderful command-line tool convertlit . With ConvertLIT, you can extract files from Microsoft proprietary ebook format .lit (see -Link- for more information), you can also downconvert (ie remove DRM protection) and inscribe lit files. Ø DirLister is an utility for listing directory contents. It can be run from GUI or Windows Explorer shell right-click menu, output may be .txt or .html. You can select recursive mode and file mask to use for listing. Also, you can include file sizes. Ø IP2country is a small application that takes an IP or host and tells you in which country the IP is located Ø ScreenMagus is an easy to use screenshot utility - can save images in .gif, .bmp, .png, .tiff and .jpeg format, minimizes to tray, can take screenshots of both active window and whole desktop Ø SimpleMAC - - - the best - - - - is a simple and free utility for changing MAC address on Windows XP and Windows 2000. It supports also changing MAC address from command line. Also, on SimpleMAC page there is a small manual for MAC cloning. Ø txt2html is a program to convert plain text files to the hypertext markup language Ø WinErrors Small utility to search Windows error messages by error code. Also contains a list of all Windows error messages. Ø WordMagus is a conversion utility that uses Microsoft Word as an engine. In addition to converting between Word formats, WordMagus employs utilities to convert or decompile some other common document formats, such as PDF, HLP, PRC/PDB, LIT and RB. ... molto utile e potente : SimpleMAC [per modificare l'indirizzo MAC di un adattatore di rete..utilissimo in molti casi] tutte queste applicazioni possono girare su pen a voi la parola ciaooooooooooooooooooooooo | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Non trovo un link per scaricarli e testarli, il sito segnalato non esiste più | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Ok, cestinato.. P.S. complimenti a icemax per il titolo "applicazioni FREE&SOURCE leggerissime ma molto potenti" [ Edited Sat 14 Feb 2009 - 16:30 ] | ||
domino |
Registered Member #9897 Joined: Fri 21 Mar 2008 - 17:57Location: Milano Posts: 600 | Ketty wrote ... Non trovo un link per scaricarli e testarli, il sito segnalato non esiste più Ciao a tutti, se può interessare, alcuni di quei programmi sono a questo -Link- ---edit--- come non detto, pensavo che i software fossero presenti in softpedia e non linkati al sito, pardon... [ Edited Sat 14 Feb 2009 - 16:35 ] | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Sì ma puntano allo stesso sito segnalato da Ice e non si scarica nulla, a meno che non sia troppo rimba oggi | ||
domino |
Registered Member #9897 Joined: Fri 21 Mar 2008 - 17:57Location: Milano Posts: 600 | txt2html | ||
domino |
Registered Member #9897 Joined: Fri 21 Mar 2008 - 17:57Location: Milano Posts: 600 | Ecco la pagina giusta -Link- | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Ecco allora sono proprio rimbambita | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Scusate, ma è proprio il principio secondo cui è stata fatta la segnalazione che non va bene. Non è colpa di icemax, ma il problema sta proprio nella mancanza di linee guida all'epoca della segnalazione. In questi casi, come dicevo a Ketty, o si analizza e si testa ogni singolo software segnalato, o si lascia perdere. E' un lavoraccio.. [ Edited Sat 14 Feb 2009 - 16:46 ] | ||
domino |
Registered Member #9897 Joined: Fri 21 Mar 2008 - 17:57Location: Milano Posts: 600 | Ho segnalato la pagina credendo che Ketty voglia appunto testare i software. | ||
