Windows Desktop |
callison |
Registered Member #10326 Joined: Tue 08 Apr 2008 - 08:09Posts: 2 | Is it possible to use my own desktop, rather than using the desktop on the PC I am using | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi callison, welcome to our forum! Unfortunately, at this moment, what you are requesting is not performable. This is mainly due to the strict relation between user settings and desktop settings. Of course, if you find something that could help to perform this task, you are welcome to signal us Best Regards ZioZione | ||
callison |
Registered Member #10326 Joined: Tue 08 Apr 2008 - 08:09Posts: 2 | Thanks, the only reason I asked is that a friend has a "U3 Scandisk" and they have this option. | ||
