Modifiche e aggiornamenti software da winPenPack 3.4Go to page >> |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | In previsione della prossima versione di winPenPack (3.5), in questo topic verranno elencati gli aggiornamenti software, le nuove inclusioni, le modifiche e i bug risolti sui software inclusi nei packs dopo il 15.05.2008, data di rilascio del winPenPack v3.4 IMPORTANTE: questo elenco si riferisce UNICAMENTE ai software inclusi nei pack. Pertanto, chi volesse collaborare può aggiungere in coda a questo post eventuali updates, facendo riferimento alla tabella ufficiale dei software: -Link- (versione 3.4).[ Edited Wed 14 May 2008 - 21:28 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-FileZilla 3.0.10-rc1 winPenPack link Aggiornamento dalla versione 3.0.9.3 alla 3.0.10-rc1 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Fri 23 May 2008 - 22:59 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Indiwiki 0.99 Link winPenPack Aggiornamento dalla versione 0.98 alla 0.99 Home: -Link- ![]() Direct link:(not portable) -Link- ![]() [ Edited Fri 23 May 2008 - 23:00 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-FileZilla 3.0.10-rc2 winPenPack link Aggiornamento dalla versione 3.0.10-rc1 alla 3.0.10-rc2 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Fri 23 May 2008 - 23:00 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-xpy 0.10 Link winPenPack Aggiornamento dalla versione 0.9.12 alla 0.10 Home: -Link- ![]() Direct Link: -Link- (English)[ Edited Fri 23 May 2008 - 23:01 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-PosteRazor 1.5 Link winPenPack Aggiornamento dalla versione 1.4 alla 1.5 Home: -Link- ![]() Direct Link: not portable -Link- ![]() [ Edited Fri 23 May 2008 - 23:01 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Icone di diverso colore a seconda del pack per la systray. L'icona personalizzata dev'essere inclusa in \winPenPack\User\winpenpack_launcher\icons e rinominata in 0.ico _ico.zip | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Pidgin 2.4.2 Link winPenPack Aggiornamento dalla versione 2.4.1 alla 2.4.2 Home: -Link- ![]() Direct Link: (not portable) -Link- ![]() [ Edited Fri 23 May 2008 - 23:02 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | MediaCoder 0.6.1.4111 Link winPenPack Aggiornamento dalla versione 0.6.1.4106 alla 0.6.1.4111 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: Non testato | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Daphne 1.35 Link winPenPack Aggiornamento dalla versione 1.34 alla 1.35 Home: -Link- ![]() Direct Link: -Link- ![]() --------------------------------------------------------- Verrà inserito come Portable Software: -Link- ![]() --------------------------------------------------------- [ Edited Fri 23 May 2008 - 23:02 ] | ||
