Aggiornamento: CloneSpyGo to page >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.31 Link winPenPack Aggiornamento dalla versione 2.3 alla 2.31 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.32 Link winPenPack Aggiornamento dalla versione 2.31 alla 2.32 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare [ Edited Mon 16 Jun 2008 - 22:52 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.33 Link winPenPack Aggiornamento dalla versione 2.32 alla 2.33 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare [ Edited Sat 12 Jul 2008 - 22:51 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.34 Link winPenPack Aggiornamento dalla versione 2.33 alla 2.34 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare [ Edited Mon 29 Sep 2008 - 15:57 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.35 Link winPenPack Aggiornamento dalla versione 2.34 alla 2.35 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.4 Link winPenPack Aggiornamento dalla versione 2.35 alla 2.4 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare Portable tips how-to: scaricare il file cpy24.exe e lanciare il setup. In fase di installazione scegliere l'opzione "Just extract all ClonSpy fils into a folder" ed estrarre i file in una cartella a piacere. Per avviare il programma eseguire CloneSpy.exe [ Edited Fri 22 May 2009 - 14:36 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.41 Link winPenPack Aggiornamento dalla versione 2.4 alla 2.41 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.5 Link winPenPack Aggiornamento dalla versione 2.41 alla 2.5 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.51 Link winPenPack Aggiornamento dalla versione 2.5 alla 2.51 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | CloneSpy 2.52 Link winPenPack Aggiornamento dalla versione 2.51 alla 2.52 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: niente da segnalare | ||
