X-WinSCP Launcher
Sun 18 May 2008 - 15:15
X-WinSCP download page
Fixed: la directory locale non viene aggiornata (avviamente) cambiando drive o percorso.
Occorre intervenire manualmente nell'ini indicando in Session_X= la sessione salvata e attivando il codice corrispondente in ;Sessions\%Session_2%|LocalDirectory=$Drive$.
Questa operazione dev'essere fatta per ogni sessione.
; Ini revision: [rev 7]
; Date: 18.05.2008
AppName=WinSCP
[FileToRun]
[Environment]
Session_1=
Session_2=
Session_3=
Session_4=
Session_5=
WinSCPHome=$Home$\$AppName$
PuttyDir=$ExeDir$\PuTTY
[Functions]
;(it optional)
;FileDelete=$ExeDir$\WinSCP.ch;WinSCP.chs;WinSCP.cs;WinSCP.de;WinSCP.es;WinSCP.fi;WinSCP.fr;WinSCP.hr;WinSCP.hu;WinSCP.jp;WinSCP.nl
;(it)
FileMove=$ExeDir$\WinSCP.it.bak|$ExeDir$\WinSCP.it
;(en)
;FileMove=$ExeDir$\WinSCP.it|$ExeDir$\WinSCP.it.bak
DirCreate=%WinSCPHome%|%PuttyDir%
FileMove=@UserProfileDir@\PUTTY.RND|@UserProfileDir@\PUTTY.RND.bak
FileCopy=%WinSCPHome%\PUTTY.RND|@UserProfileDir@\PUTTY.RND|o
FileCopy=%WinSCPHome%\WinSCP.ini|$ExeDir$\WinSCP.ini|o
[RunAfter]
FileCopy=@UserProfileDir@\PUTTY.RND|%WinSCPHome%\PUTTY.RND|o
FileDelete=@UserProfileDir@\PUTTY.RND
FileMove=@UserProfileDir@\PUTTY.RND.bak|@UserProfileDir@\PUTTY.RND
FileCopy=$ExeDir$\WinSCP.ini|%WinSCPHome%\WinSCP.ini|o
;(backup)
DirMove=$Backup$\$AppName$\backup_4|$Backup$\$AppName$\backup_5|o
DirMove=$Backup$\$AppName$\backup_3|$Backup$\$AppName$\backup_4|o
DirMove=$Backup$\$AppName$\backup_2|$Backup$\$AppName$\backup_3|o
DirMove=$Backup$\$AppName$\backup_1|$Backup$\$AppName$\backup_2|o
FileCopy=%WinSCPHome%\WinSCP.ini|$Backup$\$AppName$\backup_1\|o
FileCopy=%WinSCPHome%\PUTTY.RND|$Backup$\$AppName$\backup_1\|o
DirRemove=$Backup$\$AppName$\backup_5\backup_4
[WriteToIni=$ExeDir$\$AppName$.ini]
;(it)
Configuration\Interface|LocaleSafe=1040
Configuration\Interface|PuttyPath=%PuttyDir%\putty.exe
;(sessions)
;Sessions\%Session_1%|LocalDirectory=$Drive$
;Sessions\%Session_3%|LocalDirectory=$Drive$
;Sessions\%Session_4%|LocalDirectory=$Drive$
;Sessions\%Session_5%|LocalDirectory=$Drive$
[Options]
DeleteTemp=true
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Sat 24 May 2008 - 11:47 ]
Mon 19 May 2008 - 23:52
[rev8]
Fixed:
  1. la LocalDirectory ora viene aggiornata automaticamente senza dover intervenire nell'.ini
  2. abilitato il logging nel profilo utente (\User\WinSCP\WinSCP.log)
  3. creazione del file di configurazione direttamente in \User\WinSCP (senza passare per $ExeDir$)
  4. modificata la gestione del backup
  5. i Random seed file PUTTY.RND e winscp.rnd vengono ora creati direttamente nella cartella del profilo
  6. integrazione con PuTTY ed esportazione chiavi di registro
;    Ini revision: [rev 8]
;    Date: 19.05.2008
AppName=WinSCP
[FileToRun]
Parameters=/ini="%WinSCPHome%\WinSCP.ini"
[Environment]
[Functions]
;(it optional)
;(it)
;(en)
[RunAfter]
;(backup)
FileCopy=%WinSCPHome%\*.*|$Backup$\$AppName$\backup_1\|o
[WriteToIni=%WinSCPHome%\$AppName$.ini]
Configuration\Interface|RandomSeedFile=%WinSCPHome%\winscp.rnd
Configuration\Interface|DDTemporaryDirectory=$Temp$
Configuration\Interface\Explorer|LastLocalTargetDirectory=$Drive$\
Configuration\Logging|Logging=1
Configuration\Logging|LogFileName=%WinSCPHome%\$AppName$.log
;(it)
[WriteToPref=%WinSCPHome%\$AppName$.ini]
Format=[PREF]=[VALUE]
LocalDirectory=$Drive$\
[WriteToReg=%WinSCPHome%\PuTTY.reg]
MainKey=HKEY_CURRENT_USER\Software\SimonTatham
PuTTY|"RandSeedFile"=%WinSCPHome%\PUTTY.RND|\\"
[RunBefore]
RegEdit=%WinSCPHome%\PuTTY.reg
[Options]
DeleteTemp=true
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
Sat 24 May 2008 - 11:45
[rev9]
Aggiunto (da attivare): editor esterni per la modifica dei file.
; (editor_0)
;Configuration\Interface\Editor\0|Editor=1
;Configuration\Interface\Editor\0|ExternalEditor="%external_editor_0%"%20!.!
;Configuration\Interface\Editor\0|ExternalEditorText=1
;Configuration\Interface\Editor\0|MDIExternalEditor=1
;Configuration\Interface\Editor\0|DetectMDIExternalEditor=1
; (editor_1)
;Configuration\Interface\Editor\1|Editor=1
;Configuration\Interface\Editor\1|ExternalEditor="%external_editor_1%"%20!.!
;Configuration\Interface\Editor\1|ExternalEditorText=1
;Configuration\Interface\Editor\1|MDIExternalEditor=1
;Configuration\Interface\Editor\1|DetectMDIExternalEditor=1
INI:
x-winscp.zip
