X-WinSCP Launcher |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | --------------------------------- X-WinSCP download page --------------------------------- Fixed: la directory locale non viene aggiornata (avviamente) cambiando drive o percorso. Occorre intervenire manualmente nell'ini indicando in Session_X= la sessione salvata e attivando il codice corrispondente in ;Sessions\%Session_2%|LocalDirectory=$Drive$. Questa operazione dev'essere fatta per ogni sessione. ;------------------------------------------------------- ; Ini revision: [rev 7] ; Date: 18.05.2008 ;------------------------------------------------------- [Setup] AppName=WinSCP [FileToRun] PathToExe=$Bin$\$AppName$\$AppName$.exe [Environment] Session_1= Session_2= Session_3= Session_4= Session_5= WinSCPHome=$Home$\$AppName$ PuttyDir=$ExeDir$\PuTTY [Functions] ;(it optional) ;FileDelete=$ExeDir$\WinSCP.ch;WinSCP.chs;WinSCP.cs;WinSCP.de;WinSCP.es;WinSCP.fi;WinSCP.fr;WinSCP.hr;WinSCP.hu;WinSCP.jp;WinSCP.nl ;(it) FileMove=$ExeDir$\WinSCP.it.bak|$ExeDir$\WinSCP.it ;(en) ;FileMove=$ExeDir$\WinSCP.it|$ExeDir$\WinSCP.it.bak DirCreate=%WinSCPHome%|%PuttyDir% FileMove=@UserProfileDir@\PUTTY.RND|@UserProfileDir@\PUTTY.RND.bak FileCopy=%WinSCPHome%\PUTTY.RND|@UserProfileDir@\PUTTY.RND|o FileCopy=%WinSCPHome%\WinSCP.ini|$ExeDir$\WinSCP.ini|o [RunAfter] FileCopy=@UserProfileDir@\PUTTY.RND|%WinSCPHome%\PUTTY.RND|o FileDelete=@UserProfileDir@\PUTTY.RND FileMove=@UserProfileDir@\PUTTY.RND.bak|@UserProfileDir@\PUTTY.RND FileCopy=$ExeDir$\WinSCP.ini|%WinSCPHome%\WinSCP.ini|o ;(backup) DirMove=$Backup$\$AppName$\backup_4|$Backup$\$AppName$\backup_5|o DirMove=$Backup$\$AppName$\backup_3|$Backup$\$AppName$\backup_4|o DirMove=$Backup$\$AppName$\backup_2|$Backup$\$AppName$\backup_3|o DirMove=$Backup$\$AppName$\backup_1|$Backup$\$AppName$\backup_2|o FileCopy=%WinSCPHome%\WinSCP.ini|$Backup$\$AppName$\backup_1\|o FileCopy=%WinSCPHome%\PUTTY.RND|$Backup$\$AppName$\backup_1\|o DirRemove=$Backup$\$AppName$\backup_5\backup_4 [WriteToIni=$ExeDir$\$AppName$.ini] ;(it) Configuration\Interface|LocaleSafe=1040 Configuration\Interface|PuttyPath=%PuttyDir%\putty.exe ;(sessions) ;Sessions\%Session_1%|LocalDirectory=$Drive$ ;Sessions\%Session_2%|LocalDirectory=$Drive$ ;Sessions\%Session_3%|LocalDirectory=$Drive$ ;Sessions\%Session_4%|LocalDirectory=$Drive$ ;Sessions\%Session_5%|LocalDirectory=$Drive$ [Options] DeleteTemp=true ShowSplash=true WriteLog=false [SplashScreen] Image= Title= TimeOut=1500 [ Edited Sat 24 May 2008 - 11:47 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [rev8] Fixed:
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | [rev9] Aggiunto (da attivare): editor esterni per la modifica dei file.
; (editor_0)
INI: x-winscp.zip | ||
X-WinSCP Launcher
