PrintConductor 1.3 |
| icemax |
![]() ![]() Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 ![]() | Nome del software • PrintConductor Descrizione : PrintConductor esegue la stampa batch di 16 tipi di documenti: PDF, DOC, WRI, WPS, RTF, TXT, XLS, PPT, PPS, POT, VSD, DWG, DXF, SNP, HTM, HTML. • Nome Eseguibile• PrintCon.exe • Autore • -Link- ![]() • Email [AUTORE] • [vedi sito web] • Sito Web • -Link- ![]() • Programma [TIPO] • Setup • Linguaggio di Programmazione • C++ • Librerie richieste • nessuna • Versione • Release 1.3 • Licenza • Freeware • Dimensione File compresso • zip (534 KB) exe (559 KB) • Portabilità • 100 % [NESSUNA SCRITTURA DATI SU SISTEMA OSPITE] • Dimensione file estratti • 848 KB (868.352 byte) • Dimensione Con compressione dll ed eseguibili • 544 KB (557.056 byte) • How to - portabilità • [decomprimere con Universal Estractor e copiare il contenuto della cartella ({app}) copiare la DLL DDEML.DLL contenuta nella cartella {sys} nella cartella del programma] • Descizione • PrintConductor esegue la stampa batch di 16 tipi di documenti: PDF, DOC, WRI, WPS, RTF, TXT, XLS, PPT, PPS, POT, VSD, DWG, DXF, SNP, HTM, HTML. ¤†¤ Download Binari [ZIP] : -Link- ![]() ¤†¤ Download Binari [EXE] : -Link- ![]() [INFO ORIGINALI] PrintConductor can batch print 16 document types: PDF, DOC, WRI, WPS, RTF, TXT, XLS, PPT, PPS, POT, VSD, DWG, DXF, SNP, HTM, HTML. PrintConductor supports any printer installed on your computer and provides you with instant access to the settings of the specified printer. Add documents to the list using drag & drop, Open dialog box or auto-scan a specified folder and its subfolders for documents of needed types. Sort documents by name or type, preview before you print, and/or print any document(s) from the list. A progress bar keeps you informed of the '%complete' status of the job. And, the job can be easily cancelled at any time in processing screen shot dettaglio -Link- ![]() [ Edited Tue 27 Mar 2007 - 17:17 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Inserito nel database. Ma la versione sembrerebbe la 1.2 Thank you! ---- edit----- NOT portable - rimosso dal dababase [ Edited Tue 17 Mar 2009 - 01:05 ] | ||
PrintConductor 1.3
