The Coccinella |
Peter G |
Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | I have found an interesting Instant Messaging Application "The Coccinella", to be found here: -Link- (//coccinella.im) It's under GNU GPL and is designed for Jabber and including a "whiteboard". Maybe it's possible to bring that into a X-Package ? | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Peter G wrote ... Maybe it's possible to bring that into a X-Package ? Mmmmmhhhhh let me see..... [ Edited Mon 11 Aug 2008 - 15:29 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | AAAARRRRGGGGHHHH It's a nightmare!!!! Lots of registry voices (HKLM\classes, HKCU\Software\Microsoft), files in Appdata\Microsoft etc... Anyway, try this launcher: x-coccinella_beta.zip How to: unpack the X-Coccinella_beta.zip and put the "Coccinella Messenger-0.96.8.exe" binary (from the website) on the "X-Coccinella\Bin" folder. Attention, there is a bug: the launcher cannot export the "HKLM\Software\Classes\im" voice, maybe because the name is shorter than 3 char... Please, test it if you can, possibly using regshot... Thank you Cheers [ Edited Mon 11 Aug 2008 - 21:01 ] | ||
justsky |
Registered Member #12361 Joined: Wed 16 Jul 2008 - 06:19Posts: 28 | I just want to say that it is wonderful that you are working with this app. An open source somewhat universal IM with whiteboard that conferences and works well with slow connections. Great addition. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Hi justsky, this is only a "first and rough" attempt to create a portable version of Coccinella, needing tests and revision... Cheers | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | New beta launcher : bug Fix for registry exportations. x-coccinella_beta_2.zip As described before, put the Coccinella binary on the "\Bin\Coccinella" folder. Test needed, as usual..... Bye | ||
