[ricerca files] File Workshop v. 1.1 build 25 |
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 935 ![]() | Nome del software: File Workshop Download page: -Link- ![]() Dimensioni: KB 67 Nome autore: Andreas Demakopulos Sito web autore: -Link- ![]() Descrizione: programma per la ricerca e comparazione dei files. caratteristiche (dal sito): • Find - The fastest and most powerfull non-indexing search tool you ever had! - Search for files and/or folders - Supports multiple directory targets - Highly customizable advanced filters: name/extension/content/size/date/time/attributes - Search filters can be inclusive or exclusive - Supports specific actions to selected items in result - Supports exporting the result to file - Ensures your privacy (no traces) • Compare - A powerfull file comparator - Supports comparing by content and/or file names - Detects exact content duplicates, truncated, name matching and zero sized files - Works with a byte-to-byte optimized comparison algorithm, which eliminates any fake content duplicates in result - Supports extra optional filters like extension/size/date/attributes - Supports multiple directory targets - Supports specific actions to selected items in result - Supports exporting the result to file • Extra tools - "New Folders": A utility to automatically create a sequence of folders, alphabetic or numeric - "Create fake file": Create a fake file of any size in a second Il programma è velocissimo e funziona bene. Portable tips how-to: scaricare il file 'File_Workshop.zip' e scompattarlo. Lanciare l'eseguibile 'File Workshop.exe' contenuto nella cartella 'File_Workshop'. Versione: 1.1 build 25 Licenza: freeware (solo per uso personale) [ Edited Thu 21 Aug 2008 - 12:10 ] | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Ciao rbon, grazie per la segnalazione, in effetti il programmino non è niente male... e, naturalmente, è portatile al 100% Ho solo rilevato un problema: il "Cancel" durante le ricerche (almeno a me) non sortisce alcun effetto e manda in freeze (apparente) il programma. In altre parole, continua la ricerca fregandosene altamente delle interruzioni... Mi sono poi permesso di aggiornare la tua scheda con gli "Extra Tools" che mi sembrano altrettanto interessanti. Cordialmente ZioZione | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 935 ![]() | ciao ZioZione Ho solo rilevato un problema: il "Cancel" durante le ricerche (almeno a me) non sortisce alcun effetto e manda in freeze (apparente) il programma. In altre parole, continua la ricerca fregandosene altamente delle interruzioni... in effetti avevo scritto al programmatore che mi ha risposto così: The "Cancel" button works, but under some circumstances when the searching thread is very busy (yes, it's multithreading) it's difficult to interfere and abort or may works but not immediately. I already know about it and maybe I will improve this function (make it more "aggressive") in a future release. Anyway, this is not a bug and it will not hurt your system in any way. staremo a vedere per la prossima release. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Aggiunto al database -Link- ![]() | ||
| Andreas-D |
![]() ![]() Registered Member #14385 Joined: Fri 17 Oct 2008 - 11:35Posts: 1 | Hello my neighbors, I am Andreas Demakopoulos, the author of "File Workshop". I said "neighbors" because I live in Athens, Greece. I am writing in English because I don't know Italic (but I can read the topic through Google translator). In the first place I would like to thank the admins for their attention and I hope this tiny program to be really helpful for you. Secondly, I would like to mention that the above program has been updated. The "Cancel" function has been improved, as I promised, and working fine. The comparison algorithm has been really optimized, so I can proudly say it's the fastest file comparator out there! Also a few things added. I strongly recommend to update your listings to the newer v1.1.1.23, because of an important bug the 1.1.0.25 had. Have a nice day!!! P.S. This is really a nice forum, very good archive. [ Edited Fri 17 Oct 2008 - 12:08 ] | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Hi Andreas-D, thanks for the notice, database updated! ...and welcome on the forum | ||
