[calcolatrice programmabile] RedMill Calculator 9.0 |
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 935 ![]() | Nome del software: RedMill Calculator Download page: -Link- ![]() Dimensioni RedMilll Calculator: KB 240 Dimensioni Calculation module: KB 436 Nome autore: Alexander Muehle / RedMill Sito web autore: -Link- ![]() Descrizione: calcolatrice programmabile (orientata ai calcoli finanziari) che consente di esportare i risultati in Excel. Caratteristiche programma RedMill (Il motore) (dal sito): - a history (like a paper strip) with the current calculations - 2 Memory-functions - the calculation of variants (2 calculations in one). - Print of one or both variants - VAT/Currency calculation - Rounding to various digits, incl. commercial rounding - save of the current values when quitting (to be activated) - logging (to be activated) - change size of the history (control strip) - Switch to a small box with entries only (less coverage of the background) - Supports German / English (can be changed every time) Caratteristiche programma Calculation module (dal sito): - define your own calculations - request entries from the user when executing the definition - make calculations including complex formulas - define algorythms - check for conditions - read and write data from and to the calculator - and create your program rendering your result from the definition upon execution. - send the results back to the calculator or into MS Excel I programmi realizzati hanno l'estensione .CLD e sono dei normali files ascii contenenti le istruzioni che devono essere eseguite passo-passo da RedMill. Facile da usare. Portable tips how-to: scaricare i files 'RedMill-Rechner.exe' e 'modcalc.exe' che vanno lanciati in questo ordine. Dopo avere lanciato modcalc.exe bisogna riavviare RedMill-Rechner.exe (no bootstrap). Versione: 9.0 build 04 Licenza: GPL Dipendenze: il programma richiede il runtime VB6 (compreso in Windows) Registro il programma scrive sul registro la seguente chiave principale: HKEY_CURRENT_USER\Software\VB and VBA Program Settings | ||
