SkyIDE Ide |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Novità per questo fantastico software SkyIDE beta 12 su -Link- Discussione originale : -Link- questi gli aggiornamenti : Release Notes: SkyIDE Beta 12 - Reloaded - Sunday 1 April 2007 Added: Project Propertites next to the new Project Exlorer Added: Import Foreign Project - converts almost any non-SkyIDE project to a SkyiDE project Added: Brand new Favorites and History panes. Completely re-written Added: Move To The Recycle Bin” on Tab->Right Click popup menu. Added: Bookmaking a line now highlights the whole line instead of putting a dot Added: Deleting files/folders from project now are all moved to the Recycle Bin Added: Set #include directory in SkyIDE->Options. Used when searching for header files in “Find Function Declaration” Added: Set Source directory in SkyIDE->Options. Used when searching for source files in “Open/Show Source File” Added: The project directory text fields in “New Project” dialog are set by default to the project directory set in the SkyIDE->Options.Added: Add New Folder dialog (as part of the new project manager) Added: Explore your project folders in a Tree View-like styleAdded: Project Explorer has a second tab that lets you view/set some project settings (Preliminary feature) Added: Customized “Browse for Folder” dialog when seleting project folders - big plans with this one Added: Self Repairing Projects function if corrupted project is found - (preliminary work) Fixed: Sometimes when changing compiler profile names, projects no longer compiled Fixed: Some minor bugs in SkyIDE->Compiler PRofiles dialog box Fixed: When you search via F3/F4, SkyIDE sometimes would freeze. This error has been fixed. Fixed: When you rename a project, the project's folder also gets renamed Fixed: Fixed bugs with “for” loop detection Fixed: Access Violation bug fixed sometimes when closing tabs Fixed: Comments bug fixed /* int statements_like_this_in_a_comment_like_this */ got detected Fixed: A few start up bugs fixed Improved: The Object Viwer no longer forgets which tab was active when switching between open files Improved: The SkyIDE->Compilers dialog box. Re-arranged some buttons to make more sense Improved: Adjusted the left margin of the editor Improved: A few touch ups on the GUI - more polished Improved: The Add New Project File dialog (as part of the new project manager) Improved: “Find Function declaration” re-written. It should work much better if you set the #include dir in SkyIDE->Options Improved: “Open / Show Main File” and “Open / Show Header File” again if you set the source dir in SkyIDE->Options Improved: Re-organised the right click menu of the editor Improved: The Project Menu has been re-arranged Improved: The right click project popup menu also has been improved. Much cleaner! Improved: History an Favorites are now in one tab | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Grazie icemax, aggiorno nella sezione download | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Il programma è stato rimosso dal database, motivo -Link- [ Edited Tue 17 Mar 2009 - 03:38 ] | ||
