KOffice |
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi, I know that it's in Beta still however probably you can find it interesting enough to portabilize it - it contains among others full office suite and graphic stuff - I even dare to claim it can replace openoffice + gimp and all in consistent look&feel - after all with Qt 4 undernith - it is available for 3 main platforms which make it prety handfull - you use one tool on every platform... only problem I see is that it can be too complex - but with new x-louncher2 - who knows? :] Cheers JackL | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3374 ![]() | Hi JackL, Yeah, IMHO is too early to consider Koffice as a possible substitute of OpenOffice. For windows at the moment i able to find only a Alpha10 release! In any case is better to wait for a more stable release. if someone wants to have a look... -Link- ![]() Anyway, many thanks for Your info. | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi JackL, Taf preceeded me for few minutes Please remember that it is always better to add a link regarding the signaled software... Thank you for your support! Best Regards ZioZione P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...)[ Edited Fri 03 Oct 2008 - 09:06 ] | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3374 ![]() | ZioZione wrote ... P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...)sorry for my old link! Thanks Zio! ![]() | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Taf® wrote ... ZioZione wrote ... P.S. Taf, latest release is 2.0 beta1, that can be found here -Link- (there is a Windows Installer, it should work, but I don't have already tested...)sorry for my old link! Thanks Zio! Hi Taf, don't worry, maybe YOU are right... my link is taken directly from KOffice site, while yours is from KDe for Windows... Until test, I dont know what is the *REAL* latest one... Best Regards ZioZione | ||
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Yes - that is unclear a bit... but worth of observation though - I'm impressed by krita and some ofit's functionality (raw processing, 32bit color deth, artistic brushes/tools imitation algorythm....) If all suite is on this level of innovation - that would change the scores... cheers JackL | ||
KOffice
