[Pc Typing] Kid'S Typing Skills |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Nome del software: Kid'S Typing Skills 2.0.0.17 Direct Link al download: -Link- Dimensione File: 2,25 MB (2.369.518 byte) Nome autore: KIDwareSoftware Sito Web Autore: -Link- eMail autore: -eMail- Descrizione: Tuttor tastiera per bambini [anche un po cresciutelli ] Portable tips how-to: decomprimere il file ZIP, decomprimere il file : kidtype.CAB con universal extractor e copiare il contenuto del file decompresso in una cartella a piacere. alla fine eliminare i files : ST6UNST.EXE e SETUP1.EXE. Versione:2.0.0.17 Licenza:Freeware - - Altre info - - • Portabilità • 100 % [NESSUNA SCRITTURA DATI SU SISTEMA OSPITE] • Linguaggio di Programmazione • Visual Basic 6.0 • Lingua • ENG • info originali PROGRAM OPERATION INSTRUCTIONS Click Start, then Programs, then click the KID'S TYPING SKILLS program item. To uninstall, click Start, then ettings, then Control Panel, then Add/Remove Programs. Choose KID'S TYPING SKILLS and click Add/Remove. INTRODUCTION This program will help you learn some of the skills required for keyboarding, or typing (as it was called when typewriters were the major method of putting words on paper). You have several choices: Learn Keyboard, Keyboard Practice, Character Drills, Word Drills, Timed Drills, Help, or Exit. Make your choice by clicking on the desired Keyboard Practice: Choosing this option allows you to practice what was learned in Learn Keyboard. Select which row(s) you want to work with by clicking the desired check box(es). Decide whether you want to type characters requiring the Shift key using the Use Shift? check box. You are given a key to press and shown where it is on the keyboard. Simply press the desired key three times. The sound you hear when a key is pressed can be turned on or off using the Key Sound? check box. Click the Stop sign when done. screenshot : [ Edited Sat 21 Apr 2007 - 12:37 ] | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Questo programma a mio avviso non è portable, motivo -Link- è presente in download -Link- | ||
