Aggiornamento: RJ TextEdGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.0 Link winPenPack Aggiornamento dalla versione 4.93 alla 5.0 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Thu 09 Apr 2009 - 23:24 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.01 Link winPenPack Aggiornamento dalla versione 5.0 alla 5.01 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Wed 15 Apr 2009 - 23:01 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.10 Link winPenPack Aggiornamento dalla versione 5.01 alla 5.10 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Wed 06 May 2009 - 16:05 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.20 Link winPenPack Aggiornamento dalla versione 5.10 alla 5.20 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Sun 24 May 2009 - 11:56 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.21 Link winPenPack Aggiornamento dalla versione 5.20 alla 5.21 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Wed 27 May 2009 - 22:56 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.23 Link winPenPack Aggiornamento dalla versione 5.21 alla 5.23 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.24 Link winPenPack Aggiornamento dalla versione 5.23 alla 5.24 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Mon 08 Jun 2009 - 08:04 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | RJ TextEd 5.30 Link winPenPack Aggiornamento dalla versione 5.24 alla 5.30 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare - - - Edit Rcs- - - Corretto il numero di versione. [ Edited Sat 27 Jun 2009 - 21:58 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 483 ![]() | Rcs wrote ... RJ TextEd 5.26 Link winPenPack Aggiornamento dalla versione 5.24 alla 5.26 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare Ho controllato anche su altri siti, per es. Softpedia, e la versione portable è la 5.30. La pagina di Softpedia con la segnalazione dell'aggiornamento si trova al link -Link- .... ed infatti l'eseguibile contenuto nell'archivio riporta il numero 'interno' di versione 5.30.0.1451. Vi chiedo di aggiornare anche la descrizione nella pagina di Download. Grazie. rbon | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3819 ![]() | Ciao rbon, grazie per la segnalazione, precisa e puntuale come sempre. Confermo che la versione portable ha il numero interno di versione 5.30. A discolpa di Rcs posso solo dire che sul sito ufficiale la versione portable è ancora indicata con il numero di versione 5.26, quindi, semmai, se c'è qualcuno che deve aggiornarlo sono loro: noi lo faremo di conseguenza. Probabilmente il rilascio contemporaneo, o quasi, delle due versioni ha creato un po' di confusione nella loro numerazione... cose che capitano a chi lavora... Cordialmente ZioZione [ Edited Sat 27 Jun 2009 - 18:26 ] | ||
