[file] muCommander
Mon 05 Jan 2009 - 21:59
Nome del software: muCommander
Dimensione File: 2,4 MB
Nome autore: Maxence Bernard
eMail autore: Contact form -Link-
Descrizione: File manager a due finestre in stile NortonCommander/TotalCommander
Versione: 0.8.3
Licenza: GNU GPL v3
muCommander is a lightweight, cross-platform file manager featuring a Norton Commander style interface and running on any operating system with Java support (Mac OS X, Windows, Linux, *BSD, Solaris...).
Here's a non-exhaustive list of what you'll find:
  • Virtual filesystem with local volumes, FTP, SFTP, SMB, NFS, HTTP and Bonjour support
  • Quickly copy, move, rename files, create directories, email files...
  • Browse, create and uncompress ZIP, RAR, TAR, GZip, BZip2, ISO/NRG, AR/Deb and LST archives
  • ZIP files can be modified on-the-fly, without having to recompress the whole archive
  • Universal bookmarks and credentials manager
  • Multiple windows support
  • Full keyboard access
  • Highly configurable
  • Available in 22 languages : American & British English, French, German, Spanish, Czech, Simplified & Traditional Chinese, Polish, Hungarian, Russian, Slovenian, Romanian, Italian, Korean, Brazilian Portuguese, Dutch, Slovak, Japanese, Swedish, Danish and Ukrainian.
Not-Portable::
Il software richiede java, scrive un po' di percorsi assoluti nelle preferenze e nei boolmarks.
[ Edited Tue 06 Jan 2009 - 13:24 ]
Mon 05 Jan 2009 - 22:10
Ecco la prima versione di TEST:
==ALLEGATO RIMOSSO==
Note su questa "versione":
- Launcher 1.3 generico
- Java da inserire in Bin\Lib
- le impostazioni per aggiornamento automatico, formato data/ora e cartelle predefinite hanno effetto solo dal secondo avvio; andrebbe probabilmente previsto un fileinstall (da verificare con Danix)
- i preferiti memorizzati contengono solo percorsi assoluti, ho risolto (drasticamente) rimuovendo il file... oops
Se il software riscuote gradimento, si può lavorare a un launcher serio.
>>> Test richiesto <<<
[ Edited Tue 06 Jan 2009 - 13:41 ]
Tue 06 Jan 2009 - 00:00
Da un primo test risulta:
  1. una grafica pessima (peccato!)
  2. ma la portabilizzazione è ottima
    Compresa l'impostazione:
    <last_folder>|</last_folder>=$Drive$\
    Che invece X-Atol proprio non vuole digerire (ci ho provato anche ieri! )
  3. poco male per la data al secondo avvio, la visualizzazione iniziale non disturba più di tanto (anche tenendo conto della grafica generale dell'anteguerra..)
  4. riguardo ai preferiti io non eliminerei bookmarks.xml (potrebbero servire a chi usa il programma sullo stesso PC) ma tenterei uno StringReplace per i preferiti con percorsi che puntano alle cartelle del programma, anche se non so quanto possa essere effettivamente utile.
Tue 06 Jan 2009 - 00:26
Ma no dai.... rispetto X-Atol anche un pezzo di rapa è più bello!!!!
Vabbè, domani vedo se riesco a tirare fuori un launcher serio.
Per lo splash screen, non dovrebbe essercene bisogno, il programma ha il suo di default integrato nell'avvio.
Tue 06 Jan 2009 - 02:21
zandet2 wrote ...
Sai che non avevo cambiato tema?
Col tema Windows è graficamente ottimo!
Se non fosse che all'avvio viene mostrata la schermata che permette di effettuare la scelta, io quasi quasi imposterei:
<lookAndFeel>|</lookAndFeel>=com.sun.java.swing.plaf.windows.WindowsLookAndFeel
con preferences.xml (mascherato da x-default) che viene copiato al primo avvio..
Mi sa che questo programma prenderà il posto del bellissimo ( ) X-Atol in wpp_2gb!
[ Edited Tue 06 Jan 2009 - 02:29 ]
Tue 06 Jan 2009 - 10:35
era quello che volevo sapere...
Tue 06 Jan 2009 - 10:52
Registered Member #74
Ciao a tutti,
ribadisco che muCommander mi piace. Sto testando la portatilizzazione e presto pubblicherò le mie impressioni. L'unica cosa che non mi piace è la dipendenza da Java che, per un File Manager (che in teoria dovrebbe funzionare dappertutto), pesa un po' in negativo (senza contare l'occupazione di spazio dovuta a Java, mitigata solo in parte dal fatto che è condivisa con gli altri X-Software).
Tue 06 Jan 2009 - 13:30
Software in download !!! -Link-
Al momento non ho previsto la gestione doppia lingua, viene presa quella di default sistema
pegasocv
Tue 06 Jan 2009 - 13:40
Registered Member #6449
Peccato che non supporti i tab
kilomikesierra
Wed 28 Aug 2013 - 10:58
Registered Member #15395
Io invece ho scoperto un curioso, ma alquanto fastidioso baco, qualunque modifica in cartelle iniziali, ritorna sempre a "pendrive":\winpenpack
Dove pendrive sarebbe la lettera dell'unità dove in quel momento è presente la suite.
Il baco mi si presenta sia in xp sp3 che in windows 7 64bit
