[debugger] OllyDbg |
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Nome del software: OllyDbg Direct Link al download: -Link- Dimensione File: 2.21 MB Nome autore: Oleh Yuschuk Sorgenti (Sources page): -Link- Pagina del programma: -Link- Sito Web Autore: -Link- OllyDbg Support Forum: Softpedia: -Link- Descrizione: debugger a 32 bit per Windows (tutte le versioni) con funzioni di disassembler. Caratteristiche (dal sito): - Intuitive user interface, no cryptical commands - Code analysis - traces registers, recognizes procedures, loops, API calls, switches, tables, constants and strings - Directly loads and debugs DLLs - Object file scanning - locates routines from object files and libraries - Allows for user-defined labels, comments and function descriptions - Understands debugging information in Borland® format - Saves patches between sessions, writes them back to executable file and updates fixups - Open architecture - many third-party plugins are available - No installation - no trash in registry or system directories - Debugs multithread applications - Attaches to running programs - Configurable disassembler, supports both MASM and IDEAL formats - MMX, 3DNow! and SSE data types and instructions, including Athlon extensions - Full UNICODE support - Dynamically recognizes ASCII and UNICODE strings - also in Delphi format! - Recognizes complex code constructs, like call to jump to procedure - Decodes calls to more than 1900 standard API and 400 C functions - Gives context-sensitive help on API functions from external help file - Sets conditional, logging, memory and hardware breakpoints - Traces program execution, logs arguments of known functions - Shows fixups - Dynamically traces stack frames - Searches for imprecise commands and masked binary sequences - Searches whole allocated memory - Finds references to constant or address range - Examines and modifies memory, sets breakpoints and pauses program on-the-fly - Assembles commands into the shortest binary form - Starts from the floppy disk Test effettuato: nulla da segnalare Portable tips how-to: scaricare l'archivio 'odbg201d.zip' e scompattarlo. Lanciare il file'ollydbg.exe'. Versione: 2.01 alpha 4 Licenza: GPL Documentazione - Quick start (en): -Link- - Tutorial 1 (ita): -Link- - Tutorial 2 (ita): -Link- Documentazione su Google Andare sulla pagina principale di Google e digitare "ollydbg manuale" (senza le virgolette): verrà eseguita una ricerca su tutte le lingue, ma i primi risultati sono in italiano... Documentazione su YouTube Andare su YouTube, digitare "ollydbg" e premere invio. [ Edited Mon 08 Aug 2011 - 15:30 ] | ||
