[Released] X-Calibre 0.9.18_rev1Go to page >> |
| Moticanus |
![]() ![]() Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Nome del software: Calibre Direct Link al download: -Link- ![]() Dimensione File: 25.060.966 (23,9MB) (file .exe) Nome autore: kovidgoyal eMail autore: Sito Web Autore: -Link- ![]() Lingua: multilingua (italiano compreso) Descrizione: Software di gestione biblioteca con interfaccia pulita, ma con numerose funzioni. Possiede anche un convertitore di formati e un lettore ebook multiformato. Portable tips how-to: L'estrazione con UE non è supportata. Va installato e disinstallato. Per i test vi fornisco della mia copia install/disinstall Versione: Version: 0.4.128 Licenza: GPL ![]() Info originali: calibre is a e-book library management application. It is free, open source and cross-platform in design and works on Linux, OSX and Windows. calibre is meant to be a complete e-library solution and thus includes, library management, format conversion, news feeds to ebook conversion as well as e-book reader sync features. A full description ofFeatures as well as some Screenshots. calibre is written purely in python. Nota1: allego log di regshot. Lascia paaaarecchie tracce log_calibre.zipNota2: il lettore e-book è separato dal software principale, quindi avviabile singolarmente. ![]() [ Edited Mon 11 Feb 2013 - 17:41 ] | ||
| Moticanus |
![]() ![]() Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Direct Link al download: -Link- ![]() Versione: 0.5.0 (9.3.09) Changelog: * Fix #2003 (lrs2lrf mistranslates XML entities) * Fix #2005 (Updated recipe for NIN online) * Implement #1996 (Trimming option in cbr conversion) * Fix #2004 (PDF to EPUB conversions not working) * Fix bug causing laguage to be set to Arabic in OS X when the config dialog is run * Fix #2017 (Another PRC file cover detection issue) * Fix #2012 (epub output problems on PRS505) * New recipe for Eco Geek? by Darko Miletic * Fix #2018 ([ERROR] CSSValue: Missing token for production Choice) * Fix #2000 (Error on importing PDFs, CBZs and LRFs into Calibre) * New recipe for Miami Herald by Darko Miletic * Fix #1917 (Calibre will not close when clicking any exit button) * New recipe for Mediapart.fr by Mathieu Godlewski * New recipe for Wikinews by Darko Miletic * Remove dependency on help2man. Also significantly speds up man page generation * Fix the Opinion section of the no subscription NYTimes recipe Test effettuato: Utilizzando il contenuto della cartella di installazione il software è avviabile Note sulla portabilità: continua a lasciare parecchie tracce -> log_calibre.zip | ||
| _zulu |
![]() ![]() Registered Member #3957 Joined: Mon 09 Apr 2007 - 01:39Posts: 175 ![]() | Vi segnalo che l'autore di questo software ha realizzato una versione portabile (attualmente la 0.8.7). Non ho effettuato dei test, ma sicuramente ora il software merita un nuovo controllo. Ciao | ||
| Bourne |
![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | _zulu wrote ... Vi segnalo che l'autore di questo software ha realizzato una versione portabile (attualmente la 0.8.7). Non ho effettuato dei test, ma sicuramente ora il software merita un nuovo controllo. Purtroppo la loro versione portabile non è tale, rimane la solita chiave TrollTech. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Test richiesto/Test needed: X-Calibre_0.9.15_rev1_test1 --- edit --- Rilasciato/released: X-Calibre_0.9.18_rev1[ Edited Mon 11 Feb 2013 - 17:44 ] | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3379 ![]() | Danix wrote ... Test richiesto/Test needed: O.S. windows 7 Pro 64bit TUTTO OK! (nessuna chiave trolltech residua) ![]() | ||
| duwil |
![]() ![]() Registered Member #6659 Joined: Tue 23 Oct 2007 - 18:34Posts: 42 | Ho fatto un test di funzionalità e ho notato che impostando come default una libreria preesitente, al successivo riavvio viene reimpostata la libreria in C:\Users\nome_utente\Calibre Library". Premesso che le mie conoscenze sono limitate, se volessi usare come cartella di default per i libri una cartella su un percorso assoluto, sarebbe giusto e sufficiente ad es. modificare X-Calibre.ini così? ;Parameters=--with-library "%CALIBRE_LIBRARY_DIRECTORY%" Parameters=--with-library "K:\var\libreria" --- [ Edited Mon 21 Jan 2013 - 18:54 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | duwil wrote ... Ho fatto un test di funzionalità e ho notato che impostando come default una libreria preesitente, al successivo riavvio viene reimpostata la libreria in C:\Users\nome_utente\Calibre Library". E' una cosa voluta proprio per conservare il percorso alla libreria anche in caso di spostamento del programma da un percorso (o da un drive) all'altro. duwil wrote ... Premesso che le mie conoscenze sono limitate, se volessi usare come cartella di default per i libri una cartella su un percorso assoluto, sarebbe giusto e sufficiente ad es. modificare X-Calibre.ini così? ;Parameters=--with-library "%CALIBRE_LIBRARY_DIRECTORY%" Parameters=--with-library "K:\var\libreria" E' preferibile modificare il percorso della libreria nella variabile %CALIBRE_LIBRARY_DIRECTORY% sotto [Environment], così: [Environment] CALIBRE_LIBRARY_DIRECTORY=K:\var\libreria | ||
| duwil |
![]() ![]() Registered Member #6659 Joined: Tue 23 Oct 2007 - 18:34Posts: 42 | Grazie Danix, lo sapevo che non avevo guardato con abbastanza attenzione! ... Comunque credo di aver fatto qualcosa di "strano" nel wizard del primo avvio oppure ho fatto confusione non controllando adeguatamente cosa succedeva nelle cartelle "giuste". Eliminando le cartelle e i file di x-calibre e reinstallandolo il problema non si è ripresentato: ora la libreria viene impostata invece che su "C:\Users\nome_utente\Calibre Library" nella cartella "Documents\Calibre Library" all'interno della struttura di wpp e quindi così mi va bene. La prossima volta prima di scrivere farò una doppia prova... --- | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | X-Calibre_0.9.16_rev1_test2Attenzione: il percorso della libreria (Calibre Library) non deve essere più lungo di 75 caratteri, altrimenti appare un errore e viene creata un'altra libreria in %AppData%\Utente\Calibre Library: Siccome in X-Calibre il percorso della Libreria è preimpostato su \Documents\Calibre Library, per evitare questo inconveniente bisognerà posizionare il programma su un percorso breve (ad es.: H:\winPenPack) anzichè su un percorso troppo lungo (ad es.: C:\Documents and Settings\Utente\Desktop\X-Calibre_0.9.16_rev1). X-Calibre_0.9.16_rev1_test2Warning: the library path (Calibre Library) must have maximum 75 characters, otherwise an error will appear and another library will be created in %AppData%\User\Calibre Library: ![]() Since in X-Calibre the library path is set to \Documents\Calibre Library, to avoid this issue, it is mandatory to place the program into a short path (eg.: H:\winPenPack) instead of a longer one (eg.: C:\Documents and Settings\User\Desktop\X-Calibre_0.9.16_rev1). [ Edited Mon 11 Feb 2013 - 17:45 ] | ||
