b9b9b9 |
![]() ![]() ![]() Registered Member #264 Joined: Mon 22 Jan 2007 - 10:55Posts: 112 ![]() | Nome del software: QtWeb Direct Link al download: Eseguibile Stand-alone zippato - -Link- ![]() Dimensione File: (4.58 MB) Nome autore: LSoft Technologies. eMail autore: -eMail- ![]() Sito Web Autore: -Link- ![]() Descrizione: QtWeb e' basato su WebKit open source di Apple e sul framework Qt di Nokia (ex Trolltech). Portable tips how-to: Creare una cartella e copiarci dentro QtWeb.exe Versione: 1.5 (released Jan 16, 2009) Licenza: QtWeb e' gratuito, non commerciale ed open source [http://www.qtweb.net/about.php]. Note dal sito ------------------ Installing vs Porting (http://www.qtweb.net/pages/ibr9019.html) QtWeb settings and caches are stored differently depending on whether you installed the software, or just ported it (run the executable being copied on USB or other media). [...] If you are porting the software with you (just copied QtWeb.exe to USB or other media and run it from there, even on different machines) - neither Registry nor User's profile have not been used at all. Software should create subfolders QtWebCache and QtWebSettings at the same directory where QtWeb.exe is located, and QtWeb stores all caches and settings there. These settings and caches do not depend on the local user being logged in, and will be used by all local users. Reset and Full Reset functions will clean up all the settings and caches. Purtroppo non sono riuscito ad usare RegShot, ma ho fatto un giro rapido con regedit e verificato le solite cartelle in Doc'n'settings e non ho trovato tracce... La cosa mooolto bella e' che puo' essere usato anche con BartPe su CD, disabilitando la scrittura di cache/etc... Ciao! [ Edited Fri 23 Jan 2009 - 12:30 ] | ||
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3370 ![]() | io lo sto testando "a spot" da circa un mese su varie macchine "di servizio" (sempre da chiavetta USB). sembra proprio funzionare a dovere da USB Non è X-Firefox, ma fa egregiamente il suo dovere di Browser tascabile. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Taf, hai testato se è portatile? O necessita di un launcher? | ||
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | A naso, se utilizza QT nel registro dovrebbero andare a finire le voci "Trolltech"... | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Sembra che non scriva nulla nel registro ed inoltre salva tutto nella propria cartella. Si potrebbero fare alcune personalizzazioni nel file QtWeb Internet Browser.ini per adattarlo alla struttura di wpp, ma non so quanto ne valga la pena perché sembra già portatile. Piuttosto, è di una lentezza esasperante! ---edit------ Danix wrote ... ma non so quanto ne valga la pena perché sembra già portatile. Mi auto-quoto, facendo anche una considerazione supplementare: non penso che ne valga la pena per evitare di cadere nel ridicolo, come a volte capita -Link- ![]() [ Edited Fri 23 Jan 2009 - 15:14 ] | ||
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3370 ![]() | Portabilissimo.... ...e neppure tanto lento! (IMHO - su xp pro sp3) A me piace come browser "di emergenza" da tenere sempre anche in una mini chiavetta. Ha pure una simpatica funzione per la navigazione "in incognito"! (...per quel che può servire/valere) | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Ciao a tutti, anche a me l'altro giorno aveva fatto un'ottima impressione (sulla carta), ma poi ho provato a testarne la portatilità sul mio PC dell'ufficio e mi è andato in schermata blu (non accadeva da anni...). Sicuramente avevo qualcosa di attivo che era incompatibile, perché invece sui PC dei miei colleghi funzionava perfettamente. Non ho ancora capito cosa sia successo, ma tenete presente anche questa cosa... ovvero che potrebbe capitare anche ad altri... ![]() Cordialmente ZioZione | ||
rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 922 ![]() | ZioZione scrisse... mi è andato in schermata blu (non accadeva da anni...). ho cercato in rete dei riscontri che cominciano ad apparire numerosi e sono tutti datati dopo il 19 gennaio, segno che il problema si riferisce alla versione corrente (1.5). Tecnicamente credo si chiami BSOD (Blue Screen Of Death) e cioè schermata blu di 'blocco totale ed irreversibile' (morte) di Windows. Segnalo due post che ho trovato: - stadt-bremerhaven.de -Link- ![]() - EFB.NU -Link- ![]() Pertanto sembra che il problema si riferisca unicamente alla versione portatile e quindi suggerisco, dato che è GPL, di: 1. portabilizzare la versione install 2. decomprimere l'eseguibile che è stato compresso con UPX. Infatti sul sito -Link- ![]() Size of portable executable decreased from 12 MB to 4 MB (UPX compression applied) il che spiegherebbe in parte la lentezza all'avvio. In programma viene lanciato e si decomprime in memoria.. [ Edited Tue 27 Jan 2009 - 13:30 ] | ||
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Grossa limitazione del programma: non funziona con i proxy che richiedono user/password, oltre ad andare in crash se si cerca di modificarne le impostazioni... Forse verrà sistemata con la prossima release... -Link- ![]() | ||
b9b9b9 |
![]() ![]() ![]() Registered Member #264 Joined: Mon 22 Jan 2007 - 10:55Posts: 112 ![]() | Spero che sistemino i bug ora presenti, perche' mi sembra decisamente buono.... oddio, io lo uso essenzialmente come browser di emergenza, al posto di expl'od'er (non sia mai!), e anche con FFox non metto mai mano ai proxies. ciao | ||
