Aggiornamento: X-Crimson Editor |
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor v3.72 rev 249 Link winPenPack -Link- ![]() Aggiornamento dalla versione 3.72 r241 alla 3.72 r249 Home: -Link- ![]() Forum page: -Link- ![]() Forum Direct link: -Link- ![]() Test: non effettuato [ Edited Fri 13 Feb 2009 - 12:31 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor v3.72 rev 256 Link winPenPack -Link- ![]() Aggiornamento dalla versione 3.72 r249 alla 3.72 r256 Home: -Link- Sourceforge Download page: -Link- ![]() Sourceforge Direct download portable: -Link- ![]() Forum page: -Link- ![]() Forum Direct link portable: -Link- ![]() Test: non effettuato [ Edited Thu 08 Oct 2009 - 12:24 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor v3.72 rev 263 Link winPenPack -Link- ![]() Aggiornamento dalla versione 3.72 r256 alla 3.72 r263 Home: -Link- ![]() Sourceforge Download page: -Link- ![]() Sourceforge Direct download portable: -Link- ![]() Test: non effettuato Commenti Corretto errore su FTP: vedi forum 'Crimson Editor development', thread 'SVN 259 - FTP Issue' -Link- NB_1 Aggiornamento alla versione 263 del 21-10-2009. NB_2 Nel SVN è disponibile la versione 270. --- edit zandet2 --- software wpp aggiornato (versione 263) [ Edited Sat 31 Oct 2009 - 18:32 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor v3.72 rev 285 Link winPenPack -Link- ![]() Aggiornamento dalla versione 3.72 r263 alla 3.72 r285 Home: -Link- Forum page: -Link- ![]() Forum Direct link portable: -Link- ![]() Test: non effettuato | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor v3.72 rev 286 Link winPenPack -Link- ![]() Aggiornamento dalla versione 3.72 r263 alla 3.72 r286 Home: -Link- Sourceforge Download page: -Link- Sourceforge Direct download portable: -Link- Test: non effettuato Crimson Editor in italiano (Italian translation) A partire dal ver 3.72 r285 i menu dell'editor sono stati separati dal resto del programma e si trovano nel file "cedt_us.rc". Questo consente di creare una versione localizzata che è, a tutti gli effetti, una versione nativa come se l'editor fosse stato scritto fin dall'inizio in tale lingua. La versione italiana del file contenente i menu è stata realizzata da un utente del forum avente il nick gialloporpora". Sul sito "Emerald Editor", nel Forum su Crimson Editor si trova il thread relativo alla procedura di traduzione -Link- mentre il file contenente la traduzione italiana si trova sul sito di "gialloporpora" (vedi sotto il link per il file "cedt_it.rc").Purtroppo per ottenere la build v3.72 r286 italiana è necessario: 1. scaricare i sorgenti dal SVN 2. sostituire il file "cedt_us.rc" con il file "cedt_it.rc" 3. ricompilare i sorgenti. ............ Sul sito emeraldeditor.com si trovano le relative istruzioni: 1. How to obtain the source and submit and apply patch -Link- ![]() 2. Compiling with VS C++ Express edition 2005 -Link- ![]() Di seguito i file .rc ("resource" "c") contenti i menu: - cedt_us.rc -Link- ![]() - cedt_it.rc -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Tue 06 Apr 2010 - 15:18 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor v3.72 rev 286M Link winPenPack -Link- ![]() Aggiornamento dalla versione 3.72 r286 alla 3.72 r286M Home: -Link- ![]() Sourceforge Download page: -Link- ![]() Sourceforge Direct download portable: -Link- ![]() Test: non effettuato Nota_1 tale build è stata realizzata per velocizzare (e di molto) il tempo di avvio del programma. Nota_2 non so se è stato aggiornato l'eseguibile modificando i privilegi che il programma richiede all'avvio (la precedente build 286 richiedeva privilegi da amministratore e su Windows 7 costringeva a disabilitare lo UAC). Per tale motivo avevo modificato il file "manifest.xml" ricompilando i sorgenti. Vedi sul forum le mie build non ufficiali per Crimson Editor v3.72 rev286 nelle versioni: 1. english version: -Link- ![]() 2. italian version: -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Thu 14 Jun 2012 - 11:05 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-CrimsonEditor Link winPenPack Si prega di correggere il Sito Web dell'Autore che è crimsoneditor.com -Link- ![]() Poichè Crimson Editor viene rilasciato con licenza open source, dal sito sopraddetto è possibile scaricare il codice sorgente: Link download Source Code for release 3.71 (che è la penultima versione rilasciata) -Link- ![]() Grazie. | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3379 ![]() | Fatto! Grazie per l'avviso, rbon! | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | X-Crimson Editor 3.72-rev286M [rev5] Link winPenPack Grazie per la correzione Taf. Ho aggiornato X-Launcher per Crimson Editor alla versione 1.5.4 con le icone del programma prelevate dal vecchio X-Launcher presente nell'archivio in download. Chi è interessato può scaricare l'archivio allegato e sostituire X-Launcher ver. 1.5.0 (presente nel download di winPenPack) con X-Launcher 1.5.4. Saluti. x-crimsoneditor_launcher_rev5.zip | ||
