[Recupero dati] DiskDigger
icemax
Sun 22 Feb 2009 - 08:57
Registered Member #194
Nome Software:DiskDigger
Dimensione File: 1.29 MB (1,358,336)
Nome autore: Dmitry Brant
eMail autore: -eMail-
Descrizione: DiskDigger permette di recuperare file da qualsiasi tipo di supporto
che il computer è in grado di leggere. (unità flash USB, schede di memoria SD,
CompactFlash, Memory Stick, ecc) e, naturalmente, tutti gli hard disk.
Permette di recuperare foto, video, musica, documenti e altri formati.
DiskDigger esegue la scansione accurata di ogni settore del supporto.
Il software è in continuo aggiornamento con nuove funzioni e supporto a più formati
di file, più opzioni di configurazione, ecc. (Lingua : inglese)
Portable tips how-to: Portatile.
Versione:0.6.1
Licenza: Freeware
screenshot :
info originali :
DiskDigger scans for many different types of files, including photos, videos, music files, and documents, and displays what it finds as it scans in real time.
You can preview most of the files found by DiskDigger without having to save them to a different location first. More than that, you can preview files while DiskDigger continues scanning!
DiskDigger scans any type of media that is readable by your computer, including USB flash drives, memory cards (SD, CompactFlash, Memory Stick, etc), and your hard drive(s). Also, it is completely independent of the type of file system that’s present in your media. The program bypasses the file system and reads the raw data chunks (sectors) to recover data.
DiskDigger can even recover fragments of some files, like partially overwritten photos or other images.
DiskDigger does everything in memory, meaning that it never writes any temporary files to your disk or other media (unless you choose to save files that it recovers).
Since DiskDigger is a completely self-contained program, it leaves no trace on the computer where it is run. It does not save any settings to the registry. There is nothing to “install,” and the entire program is a single executable file.
Thu 26 Feb 2009 - 19:56
Registered Member #675
Aggiunto al Database -Link-
