![]() Go to page << >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 4.0 build 724 Link winPenPack Aggiornamento dalla versione 4.0 build 723 alla 4.0 build 724 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 4.0 build 725 Link winPenPack Aggiornamento dalla versione 4.0 build 724 alla 4.0 build 725 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.0 build 733 Link winPenPack Aggiornamento dalla versione 4.0 build 725 alla 5.0 build 733 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: niente da segnalare Changelog: Per attivare la modalità "portatile" basta creare un file vuoto rapidee.ini / To enable "portable mode" just create empty rapidee.ini file [ Edited Fri 03 Jun 2011 - 14:51 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.0 build 737 Link winPenPack Aggiornamento dalla versione 5.0 build 733 alla 5.0 build 737 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download [ Edited Mon 13 Jun 2011 - 21:44 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.0 build 743 Link winPenPack Aggiornamento dalla versione 5.0 build 737 alla 5.0 build 743 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.0 build 745 Link winPenPack Aggiornamento dalla versione 5.0 build 743 alla 5.0 build 745 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.1 build 751 Link winPenPack Aggiornamento dalla versione 5.0 build 745 alla 5.1 build 751 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.1 build 752 Link winPenPack Aggiornamento dalla versione 5.0 build 751 alla 5.1 build 752 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 5.1 build 754 Link winPenPack Aggiornamento dalla versione 5.0 build 752 alla 5.1 build 754 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Rapid Environment Editor 6.0 build 777 Link winPenPack Aggiornamento dalla versione 5.1 build 754 alla 6.0 build 777 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: seguire le istruzioni della pagina download | ||
