Aggiornamento: DiskDigger Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.0.7.755 Link winPenPack Aggiornamento dalla versione 1.0.6.704 alla 1.0.7.755 Home: -Link- Direct link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.0.8.793 Link winPenPack Aggiornamento dalla versione 1.0.7.755 alla 1.0.8.793 Home: -Link- Direct link: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.0.8.812 Link winPenPack Aggiornamento dalla versione 1.0.8.793 alla 1.0.8.812 Home: -Link- Direct link: -Link- Risultato Test: niente da segnalare [ Edited Sun 21 Aug 2011 - 11:58 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.0.9.859 Link winPenPack Aggiornamento dalla versione 1.0.8.812 alla 1.0.9.859 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Sat 03 Sep 2011 - 10:36 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.0.10.915 Link winPenPack Aggiornamento dalla versione 1.0.9.859 alla 1.0.10.915 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.1.0.1077 Link winPenPack Aggiornamento dalla versione 1.0.10.915 alla 1.1.0.1077 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.5.0.1200 Link winPenPack Aggiornamento dalla versione 1.1.0.1077 alla 1.5.0.1200 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.5.1.1273 Link winPenPack Aggiornamento dalla versione 1.5.0.1200 alla 1.5.1.1273 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.5.2.1312 Link winPenPack Aggiornamento dalla versione 1.5.1.1273 alla 1.5.2.1312 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare Nota: Quando viene usato in Windows, DiskDigger è gratuito per il download, la scansione del disco e la visualizzazione in anteprima dei file recuperabili. Tuttavia, quando si salvano i file recuperabili, il programma consiglia vivamente di acquistare una licenza personale. Per utilizzare il programma per scopi commerciali, è necessario acquistare una licenza commerciale. (Quando si utilizza DiskDigger in Linux, è completamente gratuito.) When using it in Windows, DiskDigger is free for downloading, scanning your disk, and previewing any recoverable files. However, when saving the recoverable files, the program strongly encourages you to purchase a personal license. To use the program for commercial purposes, you must purchase a commercial license. (When using DiskDigger in Linux, it's completely free.) [ Edited Tue 05 Jun 2012 - 15:30 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | DiskDigger 1.5.3.1355 Link winPenPack Aggiornamento dalla versione 1.5.2.1312 alla 1.5.3.1355 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
