[Dock menu avvio] Appetizer |
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Nome del software: Appetizer Direct Link al download: -Link- Dimensione File: 1,28 MB / 1342177 Byte Nome autore: Laurent Cozic eMail autore: -eMail- Sito Web Autore: -Link- Progetto su SourceForge.net: -Link- Descrizione: Applicazione portatile che funge da menu di avvio per file, cartelle o programmi. Consente di importare collegamenti dal menu Start di Windows o dal menu di avvio rapido, oppure creare collegamenti ad applicazioni portatili. Interfaccia anche in italiano, con skins modificabili, trasparenza e orientamento (orizzontale/verticale) regolabile. Descrizione originale: This is a free application launcher, or dock, for Windows. It allows organizing your shortcuts and folders into a convenient dock. The app is open source, which means that it's free and will remain so. It is entirely customizable and is available in multiple languages. Portable tips how-to: decomprimere il file Appetizer_1.3.1.222.zip ed avviare il programma eseguendo Appetizer.exe Test effettuato: come indicato sul sito originale il software non sporca il registro -> log.zip Versione: 1.3 Licenza: GPL v. 3 Screenshot: Features * Support for plugins * Support for multiple skins (two included) * Resizable dock, which allows displaying the icons both horizontally or vertically. * Three sizes of icons: Small, large and extra-large * Support for custom icons * 'Wizard' to automatically imports shortcuts from various locations * Organize the icons by drag & dropping them * 'Multi-launch' functionality * Regroup multiple shortcuts within one menu * Hot key to hide / show the dock * Special items to provide extra functionalities: hide / show the desktop, Recycle Bin, Control Panel, etc. * Support for multiple languages * Minimize to tray icon functionality [ Edited Sun 26 Apr 2009 - 08:43 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | E' assurdo ma il menù non è portatile. I percorsi scritti nei file di configurazione all'interno della cartella "Data" devono essere normalizzati e corretti nel passaggio da un drive (o percorso) all'altro. Altrimenti non funzionano. Spostato in Richieste. | ||
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Danix wrote ... E' assurdo ma il menù non è portatile. Se consideri poi che è stato incluso in un famoso progetto di software portatile...lo è ancora di più!!! I percorsi scritti nei file di configurazione all'interno della cartella "Data" devono essere normalizzati e corretti nel passaggio da un drive (o percorso) all'altro. Altrimenti non funzionano. Purtroppo questo tipo di controllo non posso al momento farlo! | ||
