[P2P] Tribler |
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Nome del software: Tribler Direct Link al download: -Link- Dimensione File: 22 MB / 23068672 Byte Nome autore: Electrical Engineering, Mathematics and Computer Science faculty eMail autore: -eMail- Sito Web Autore: -Link- Descrizione: BitTorrent dotato di un’interfaccia semplice ed intuitiva. La sua ricerca è basata su un sistema distribuito tra i vari peer, senza appoggiarsi ai siti torrent come ThePirateBay, Mininova ed altri… la ricerca dei file torrent, inoltre, avviene direttamente dal software senza dover ricorrere ai siti torrent dal browser. Portable tips how-to: è possibile estrarlo con UE, ma non si avvia. Test effettuato: eseguendo tribler.exe restituisce errore: Note: Tribler won't start (again) There may be several reasons for that. Please check that the install directory you select is writable (e.g. on Windows you need to be Computer Administrator to write to C:\Program Files). If your username contains special characters, please check this bugreport #304 (the NSIS installer software we use can't handle that). Tribler itself can handle them, starting with version 5.1 (we hope). If Tribler fails to restart, you have stumbled upon a bug, unfortunately. To get things working again, you should delete some files from the .Tribler directory: For Windows: C:\Documents and Settings\User\Application Data\.Tribler where "User" should be replaced by your own user name. To locate this directory, you may have to enable "Show hidden files and folders" in the "Tools / Folder Options / View" menu of the Windows explorer. Versione: 5.1.2 Licenza: LGPL Open Source license Screenshot: Fonte descrizione:
http://ilarialab.com
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | - Aggiornamento - Portable tips how-to: utilizzando la cartella di installazione del software ed eseguendo tribler.exe il software si avvia normalmente. Test effettuato: come previsto non è nativamente portatile --> log_tribler.zip Si noti in particolare: Spoiler: | ||
