ULTRA Version -- I want it ALL!!! |
| PaulJOttCan |
![]() ![]() Registered Member #9797 Joined: Tue 18 Mar 2008 - 17:40Posts: 1 | I want all the apps as one option. So this might come to 3GB, it's okay. Or, even better, a user-selectable list of apps to custom include (server-side auto-generates a specialized XML file for the Launcher menu and a custom ZIP file). However, since you're already worried about bandwidth, this would be bad (unless you cached them according to the selected apps). Make the ULTRA version only downloadable via bittorent. | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi PaulJOttCan, welcome to our forum! PaulJOttCan wrote ... I want all the apps as one option. So this might come to 3GB, it's okay. (...) Make the ULTRA version only downloadable via bittorent. A very huge download, isn't it? At this moment, with all the updates that occur so frequently, to maintain a such file is quite impossible. Also, we don't have planned, at this moment, any torrent download, but who can say for the future...? PaulJOttCan wrote ... Or, even better, a user-selectable list of apps to custom include (server-side auto-generates a specialized XML file for the Launcher menu and a custom ZIP file). However, since you're already worried about bandwidth, this would be bad (unless you cached them according to the selected apps). This is also our dream... We are working on it (if possible, for integrate this option in the wPP menu), but we have so few resources, that also the simplest task takes a long time... If you want to collaborate, you are welcome! Best Regards ZioZione | ||
