Open Office Fonts |
fcarson |
Registered Member #35890 Joined: Tue 25 Aug 2009 - 11:42Posts: 2 | How do I add fonts to Portable Open Office Impress? I'm using Portable Impress for presentations via several PCs that are not mine. The fonts I want to use are not installed on these PCs. Am I stuck with the core fonts that are in stalled in Impress? Or is there a way to add fonts to the portable environment and not the host PC? Thanks for your assistance. | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi fcarson, as I know, at this moment OpenOffice.org uses only the fonts installed in the host PC. You could try a couple of tricks: 1) Use FontOOo -Link- and see if it works as they declare ("FontOOo only installs fonts for OpenOffice.org and doesn't perform any OS level font installation."). I don't know if this is possible also for portable version, but you can try... 2) Embed fonts into the document, saving in PDF hybrid format, as you can see here: -Link- Hope it helps... Best Regards ZioZione | ||
