![]() Go to page >> |
bagr |
![]() ![]() ![]() Registered Member #4759 Joined: Sat 19 May 2007 - 09:25Posts: 15 | Software name: X-Tor (original as Tor) Direct Link to download: -Link- ![]() File size: 6.25MB Website: -Link- ![]() Description: Tor is a toolset for a wide range of organizations and people that want to improve their safety and security on the Internet. Using Tor can help you anonymize web browsing and publishing, instant messaging, IRC, SSH, and other applications that use the TCP protocol. Tor also provides a platform on which software developers can build new applications with built-in anonymity, safety, and privacy features. Portable tips how-to: Download Tor (vidalia-bundle) extract with uniExtract copy folders Prioxy, Tor, Vidalia to Bin folder. geoip-cache which is in $APPDATA\Vidalia\ copy in Vidalia and folder $_OUTDIR\templates to Prioxy. To use Tor with firefox install torbutton-1.0.4-fx+tb.xpi which is in Torbutton folder. Version: X-Tor alpha (vidalia-bundle-0.1.2.13-0.0.11) License: GNU 2 This is only a start of .ini files some more changes should be done, but is a start. ======X-Tor.ini=============== [Setup] AppName=Tor [FileToRun] PathToExe=$Bin$\Vidalia\vidalia.exe Parameters= --datadir "$Home$\Vidalia\" [RunBefore] RunFile=$Bin$\Privoxy\privoxy.exe | "$Bin$\Privoxy\config.txt" [Options] DeleteTemp=true ShowSplash=false WriteLog=false [SplashScreen] Image= Title= TimeOut=1000 [ Edited Thu 24 May 2007 - 21:19 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12926 ![]() | It's fine! ![]() Can you try to integrate it in X-Firefox? [ Edited Thu 24 May 2007 - 22:26 ] | ||
bagr |
![]() ![]() ![]() Registered Member #4759 Joined: Sat 19 May 2007 - 09:25Posts: 15 | Can you try to integrate it in X-Firefox? To integrate it in X-Firefox add attached file in X-Firefox_2.0.0.3_EN\User\Firefox\Profiles\Default\extensions\ leave name of the folder as is ( e0204bd5-9d31-402b-a99d-a6aa8ffebdca ) start X-firefox and at bottom (status) bar there is red Tor button. I tested torbutton-1.0.4-fx+tb with X-Firefox2.0.0.3_EN ![]() [ Edited Fri 25 May 2007 - 19:36 ] | ||
AlexF.RS3 |
![]() ![]() ![]() Registered Member #5104 Joined: Mon 11 Jun 2007 - 10:21Location: Latina Posts: 450 ![]() | Da dove scarico il launcher? Grazie. | ||
domino |
![]() ![]() ![]() Registered Member #9897 Joined: Fri 21 Mar 2008 - 17:57Location: Milano Posts: 600 ![]() | AlexF.RS3 wrote ... Da dove scarico il launcher? Grazie. Ciao AlexF.RS3, non puoi scaricare il launcher, non è stato creato fisicamente, fai in questo modo: crea un nuovo documento di testo, incolli al suo interno questo codice: [Setup] AppName=Tor [FileToRun] PathToExe=$Bin$\Vidalia\vidalia.exe Parameters= --datadir "$Home$\Vidalia\" [RunBefore] RunFile=$Bin$\Privoxy\privoxy.exe | "$Bin$\Privoxy\config.txt" [Options] DeleteTemp=true ShowSplash=false WriteLog=false [SplashScreen] Image= Title= TimeOut=1000 poi rinomini il file in X-Tor.ini | ||
AlexF.RS3 |
![]() ![]() ![]() Registered Member #5104 Joined: Mon 11 Jun 2007 - 10:21Location: Latina Posts: 450 ![]() | Si, l'ini l'ho capito come crearlo, Non ho capito come avvio il programma. Quale eseguibile devo utilizzare? ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12926 ![]() | Scarica X-Launcher -Link- ![]() | ||
AlexF.RS3 |
![]() ![]() ![]() Registered Member #5104 Joined: Mon 11 Jun 2007 - 10:21Location: Latina Posts: 450 ![]() | Ho seguito tutta la procedura, ma quando avvio X-Tor, appare questo avviso: "Vidalia non è riuscito ad avviare Tor. Controlla le impostazioni per assicurarti di aver specificato nome e posizione corretti per l'eseguibile di Tor." Dopo aver specificato il percorso di Tor appare: "Vidalia detected that the Tor software exited unexpectedly. Please check the message log for recent warning or error messages." Il log è il seguente: set 07 12:29:47.125 [Eventi] Tor v0.2.0.30 (r15956). This is experimental software. Do not rely on it for strong anonymity. (Running on Windows XP Service Pack 2 [workstation] {personal} {terminal services, single user}) set 07 12:29:47.171 [Avvisi] Unable to open configuration file "C:\Documents and Settings\AlexF.RS3\Desktop\AlexF.RS3\winPenPack\User\Vidalia"\torrc". set 07 12:29:47.171 [Errori] Reading config failed--see warnings above. Cosa devo fare? Perchè questo SW non viene integrato nei download, senza che ognuno debba seguire tutta la procedura manualmente? Grazie | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12926 ![]() | AlexF.RS3 wrote ... Perchè questo SW non viene integrato nei download, senza che ognuno debba seguire tutta la procedura manualmente? I motivi possono essere molteplici: numero eccessivo di software da aggiornare/portabilizzare che ci impedisce di seguire tutte le richieste, tempo dedicato all'assistenza agli utenti, poco tempo a disposizione, dimenticanza, etc.. Ad ogni modo, ho provato a portabilizzare Tor. Il pacchetto contiene Tor, Vidalia (intefaccia grafica per Tor), Privoxy (un filtro web proxy) e l'estensione per Firefox Torbutton che verrà aggiunta automaticamente a X-Firefox (nota: X-Tor e X-Firefox devono seguire la struttura di winPenPack). Mi auguro che tutto funzioni a dovere. ![]() --------------------- TEST RICHIESTO --------------------- ![]() ![]() | ||
justsky |
![]() ![]() Registered Member #12361 Joined: Wed 16 Jul 2008 - 06:19Posts: 28 | I am being asked for a control password. I do not know the default password and when I go to settings and enter a new password I get no error but the change is ignored so I can never start tor. Also, I think the proxy port is 8118 but I am not sure. | ||
