[internet] X-Tor (alpha)Go to page << |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Danix wrote ... ------------------------------------------------------------------------ EDIT: Privoxy dovrebbe essere avviato come servizio -Link- (le risposte risalgono però al 2006) ------------------------------------------------------------------------ Nel file di configurazione è possibile settare una serie di opzioni, ma nessuna sembra permettere l'avvio ridotto ad icona: # 6. WINDOWS GUI OPTIONS # ======================= # # Privoxy has a number of options specific to the Windows GUI # interface: # # # If "activity-animation" is set to 1, the Privoxy icon will animate # when "Privoxy" is active. To turn off, set to 0. # #activity-animation 1 # # If "log-messages" is set to 1, Privoxy will log messages to the # console window: # #log-messages 1 # # If "log-buffer-size" is set to 1, the size of the log buffer, # i.e. the amount of memory used for the log messages displayed in # the console window, will be limited to "log-max-lines" (see below). # # Warning: Setting this to 0 will result in the buffer to grow # infinitely and eat up all your memory! # #log-buffer-size 1 # # log-max-lines is the maximum number of lines held in the log # buffer. See above. # #log-max-lines 200 # # If "log-highlight-messages" is set to 1, Privoxy will highlight # portions of the log messages with a bold-faced font: # #log-highlight-messages 1 # # The font used in the console window: # #log-font-name Comic Sans MS # # Font size used in the console window: # #log-font-size 8 # # "show-on-task-bar" controls whether or not Privoxy will appear as # a button on the Task bar when minimized: # #show-on-task-bar 0 # # If "close-button-minimizes" is set to 1, the Windows close button # will minimize Privoxy instead of closing the program (close with # the exit option on the File menu). # #close-button-minimizes 1 # # The "hide-console" option is specific to the MS-Win console version # of Privoxy. If this option is used, Privoxy will disconnect from # and hide the command console. # #hide-console # # [ Edited Tue 09 Sep 2008 - 11:08 ] | ||
| AlexF.RS3 |
![]() ![]() Registered Member #5104 Joined: Mon 11 Jun 2007 - 10:21Location: Latina Posts: 450 ![]() | Danix wrote ... Nel file di configurazione è possibile settare una serie di opzioni, ma nessuna sembra permettere l'avvio ridotto ad icona: Poco fa ho notato che andando su Proprietà di un collegamento è possibile scegliere le varie grandezze della finestra dell'applicazione che deve essere avviata tra cui c'è anche rid. a icona. Non si potrebbe quindi modificare il file .ini in modo che esegua il collegamento opportunatamente modificato? E' una cosa possibile? [ Edited Tue 09 Sep 2008 - 15:10 ] | ||
| spydy00 |
![]() ![]() Registered Member #338 Joined: Mon 22 Jan 2007 - 15:42Posts: 34 | Ciao Danix Se ci sono problemi con la finestra di Privoxy perché non usare un'alternativa Tor+Polipo nella rete e pieno di esempi : -Link- ![]() -Link- ![]() -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Sai già come configurare Tor con Polipo? Indicazioni? ![]() | ||
| spydy00 |
![]() ![]() Registered Member #338 Joined: Mon 22 Jan 2007 - 15:42Posts: 34 | Ciao Danix. Me la cavo malissimo con l'inglese. Da una ricerca nella rete link principale del progetto Polipo -Link- ![]() Dove si trova il manuale, le istruzioni per installazione e configurazione con windows. Spero di essere stato utile. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Mi sono accorto che l'installer copia in %appdata%\Vidalia il file geoip-cache: geoip-cache.zipLeggo nel change-log alcuni riferimenti: o Tolerate entries in geoip-cache that have no timestamp. If an entry does not have a timestamp, use the current date and time. o Start shipping a geoip-cache file in our Win32 installers so people have some initial geographic information, instead of starting out entirely empty-handed. E in questo post: "geoip-cache which is in $APPDATA\Vidalia\ copy in Vidalia" Domanda 1: questo file, che funzione ha? Domanda 2: va copiato in \User\Vidalia o in \Bin\Vidalia per esser letto dal programma? [ Edited Sat 14 Feb 2009 - 13:45 ] | ||
| spydy00 |
![]() ![]() Registered Member #338 Joined: Mon 22 Jan 2007 - 15:42Posts: 34 | spydy00 wrote ... Ciao Danix Se ci sono problemi con la finestra di Privoxy perché non usare un'alternativa Tor+Polipo nella rete e pieno di esempi : -Link- ![]() -Link- ![]() -Link- ![]() Ciao Danix. Un saluto a tutto il forum. Vedo con piacere che si e riusciti a integrare Tor+Polipo. Come mai si e preferito lasciare ancora Privoxy anche se disabilitato da come si vede dall'.ini: ;(Privoxy) ;General|ProxyExecutable=$Bin$\Privoxy\privoxy.exe|\\ ;General|ProxyExecutableArguments=%Privoxy_Home%\config.%Privoxy_Ver%.txt|\\" E non rimuoverlo totalmente? L'accoppiata Tor+Polipo e di gran lunga superiore da come si legge in giro. Ciao da spydy00. | ||
Go to page <<
