X-GVim 7.2_rev_1_test_1 |
pir |
Registered Member #2110 Joined: Thu 01 Feb 2007 - 20:42Location: France Posts: 14 | Please find hereafter the first test release version of X-GVim ((G)Vim home page First TEST Version (8.732.347 Byte/8,32 Mo) X-GVim_7.2_rev_1_test_1 Some Portalisation notes - I have chosen to affect the $VIM environment variable to redirect vim to the configuration files on the USB key instead of using the $HOME environment variable (both solution work). This allow me to use the $HOME environment variable to point to my document folder and use it as is in my .vimrc files. - In the same idea I have redirect _viminfo file in the $VIM directory (with the configuration files) to have a cleaner Documentation folder. This is done using the '-i' command line directive. - Before running Gvim, the launcher adapt _viminfo file content to reflect the current USB drive letter. I didn't use the FixDriveLetter directive that come with x-launcher v1.4 as it doesn't cover my needs (basically I want only to modify the path linking to documents on the key and to protect path linking to actual document on the host computer). I do this by creating my own FixDriveLetter routine (in x-udf-extra.au3 and by adpating x-launcher.au3 code). Nevertheless, if you don't like my approach, the X-GVim.ini file is still compatible with vanilla FixDriveLetter of x-launcher.au3 v1.4 - This x-launcher is designed for the gvim version compiled without ole support as I don't have managed the registry keys that come with the ole registration (and as I don't use this feature). | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Hi pir, welcome to winPenPack and thank you for using the winPenpack Platform to make portable VGim. It was a good choice! We'll test it as soon as we can.. ---- edit ---- Topic moved to "Pre-release/Beta versions" and renamed to "X-GVim 7.2_rev_1_test_1" [ Edited Sat 09 Jan 2010 - 16:30 ] | ||
