[GRAFICA] PhotoWipe 1.10 (open source) |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Nome del software: PhotoWipe basato su Greycstoration Direct Link al download: -Link- Dimensione File: 833 KB (853.037 byte) decompresso con UE] Nome autore: nd eMail autore: -nd Sito Web Autore: -Link- Descrizione: PhotoWipe è un programma di fotoritocco rivoluzionario che permette di rimuovere MAGICAMENTE oggetti o porzioni contenute nell'immagine, riscrivendo le zone con il colore originale delle zone limitrofe. Veramente MAGICO. Portable tips how-to: decomprimere con universal extractor e il programma risulterà già portatile. Versione: Version 1.10 - Released March 17, 2007 Licenza: open source screenshot [vari con immagini di esempio] esempio PRIMA e.. DOPO PRIMA DOPO Greycstoration library PhotoWipe uses a modified version of the greycstoration image processing library, which was created by David Tschumperlé. The library has been changed to be able to communicate with the main PhotoWipe program via shared memory and windows messages, which are must faster than temporary files. In compliance with with license agreement, you can download the source code here. Original Info : products | contact PhotoWipe Current release: March 20, 2007 (click to enlarge)PhotoWipe is a revolutionary image processing tool that magically removes unwanted objects from your photos. Just paint over them in black, and click go! Uncovers hidden details in your photos. Sit back and watch as cage bars disappear from the zoo, and your old girlfriend or boyfriend fades away. It removes wrinkles, or it can remove entire facial features. PhotoWipe uses a modified version of the greycstoration image processing library do its work. You can see more samples of this incredible tool [ Edited Thu 31 May 2007 - 20:28 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Attenzione: non è open Source: * Restrictions You may not publish, display, disclose, rent, lease, modify, loan, distribute, or create derivative works based on the Software or any part thereof. You may not reverse engineer, decompile, translate, adapt, or disassemble the Software, nor shall you attempt to create the source code from the object code for the Software. You may transfer the Software to other computers you own as long as you only use it on one computer at a time. A dire il vero l'rtf inserito nella cartella del programma è talmente confuso che non si capisce niente. [ Edited Sat 02 Jun 2007 - 15:54 ] | ||
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | invio subito una email per l'autorizzazione | ||
