Aggiornamento: XMedia RecodeGo to page >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.4.4 Link winPenPack Aggiornamento dalla versione 2.2.4.2 alla 2.2.4.4 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Wed 04 Aug 2010 - 00:26 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.4.7 Link winPenPack Aggiornamento dalla versione 2.2.4.4 alla 2.2.4.7 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Fri 23 Jul 2010 - 07:29 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.5.0 Link winPenPack Aggiornamento dalla versione 2.2.4.7 alla 2.2.5.0 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Tue 27 Jul 2010 - 15:16 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.5.3 Link winPenPack Aggiornamento dalla versione 2.2.5.0 alla 2.2.5.3 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Not Portable Cartella aggiunta:1 ---------------------------------- C:\Documents and Settings\Rcs\Dati applicazioni\XMedia Recode File aggiunto:1 ---------------------------------- C:\Documents and Settings\Rcs\Dati applicazioni\XMedia Recode\XMediaRecode.ini Rimane in download la versione 2.2.5.0 [ Edited Wed 04 Aug 2010 - 00:25 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.5.8 Link winPenPack Aggiornamento dalla versione 2.2.5.3 alla 2.2.5.8 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Portable Test by Taf con win 7 pro 64bit: scaricando la nuova versione, all'interno del file "XMediaRecode2258.zip" esiste un file xmediarecode.ini con impostato "Portable=1" il problema precentemente evidenziato è quindi stato risolto. Scheda download aggiornata [ Edited Tue 17 Aug 2010 - 09:53 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.6.3 Link winPenPack Aggiornamento dalla versione 2.2.5.8 alla 2.2.6.3 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Sun 29 Aug 2010 - 08:29 ] | ||
| pegasocv |
![]() ![]() Registered Member #6449 Joined: Wed 10 Oct 2007 - 21:16Posts: 430 ![]() | XMedia Recode 2.2.6.5 Link winPenPack Aggiornamento dalla versione 2.2.6.3 alla 2.2.6.5 Home: -Link- ![]() Direct link: -Link- ![]() EDIT By TAF sistemato link di DL diretto non funzionante. @pegasocv: per il DL devi inserire il link diretto al file, scritto così "
http://www.xmedia-recode.de/download/nomefile.zip
Risultato test: TESTATO! (by Taf) niente da segnalare [ Edited Mon 30 Aug 2010 - 08:15 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.6.8 Link winPenPack Aggiornamento dalla versione 2.2.6.5 alla 2.2.6.8 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Sat 04 Sep 2010 - 00:29 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.7.2 Link winPenPack Aggiornamento dalla versione 2.2.6.8 alla 2.2.7.2 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Mon 20 Sep 2010 - 22:38 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8943 ![]() | XMedia Recode 2.2.7.7 Link winPenPack Aggiornamento dalla versione 2.2.7.2 alla 2.2.7.7 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: niente da segnalare [ Edited Mon 04 Oct 2010 - 15:43 ] | ||
