Aggiornamento: X-CdrTools FrontEnd Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.8 Link winPenPack Aggiornamento dalla versione 1.3.7 alla 1.3.8 Home: -Link- Direct Link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Wed 28 Jul 2010 - 10:24 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.8.1 Link winPenPack Aggiornamento dalla versione 1.3.8 alla 1.3.8.1 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.9 Link winPenPack Aggiornamento dalla versione 1.3.8.1 alla 1.3.9 Home: -Link- Direct Link: -Link- --- edit zandet2 --- software wpp aggiornato Nota: alcuni moduli presenti in Bin\cdrtfe\tools\sound sono stati decompressi da UPX poichè causavano falsi positivi con antivirus. [ Edited Fri 17 Sep 2010 - 11:41 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.4.0 Link winPenPack Aggiornamento dalla versione 1.3.9 alla 1.4.0 Home: -Link- Direct Link: -Link- [ Edited Tue 01 Nov 2011 - 19:05 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.4.1 Link winPenPack Aggiornamento dalla versione 1.4.0 alla 1.4.1 Home: -Link- Direct Link: -Link- | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | qui siamo indietro di 2 versioni! testato la 1.41 con il vecchio launcher. Per me è tutto OK! | ||
kilomikesierra |
Registered Member #15395 Joined: Mon 24 Nov 2008 - 14:14Location: Torino Posts: 119 | Io ho copiato la cartella della versione portatile al posto della vecchia, vedo cosa succede. [ Edited Wed 21 Mar 2012 - 12:22 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Taf wrote ... qui siamo indietro di 2 versioni! testato la 1.41 con il vecchio launcher. Per me è tutto OK! Ho corretto diverse cose: Ho anche integrato un lettore audio per evitare di installare un X-Software supplementare. Fatemi sapere se quest'ultimo elemento può tornare utile! | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Danix wrote ... ... aggiornamento a X-Launcher 1.5.0, aggiunto ShowTrayTip, ... Uuuuu, prima uscita pubblica??? Ciao! | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Danix wrote ... Ho anche integrato un lettore audio per evitare di installare un X-Software supplementare. Fatemi sapere se quest'ultimo elemento può tornare utile! Simpatica l'idea! Ma se hai già un programma predefinito per le tracce audio (nel mio caso AIMP) parte comunque il programma predefinito. Oltretutto è corretto che sia così! | ||
