[Bug] X-Chromium versions above 7.0.xxx
gibdemaffen
Wed 29 Sep 2010 - 07:18
Registered Member #38871
Hey Guys,
i'm using the original X-Chromium package you are offering for download and i'm updating it myself everytime a new dev version comes around (simply by downloading the exe from -Link- [replace xxx.x with the version number e.g. 517.24] unpacking it using 7zip and putting the files into your ..\bin\chrome directory).
However I noticed that using any version of Chrom(e)(ium) above 7.0.xxx creates a new folder in the users home directory called "Downloads". Versions below 7.0.xxx didn't do that - they correctly used the Download folder in your X-Chromium package (which was given to them by the .ini file)
Obviously something changed with the v7 in that respect.
Please have a look into that and fix it.
Thanks for you awesome work
