Aggiornamento: ArcConvertGo to page >> |
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.6b1 ![]() Aggiornamento dalla versione 0.49.5 alla 0.49.6b1 Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Fri 24 Aug 2007 - 15:31 ] | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.7![]() Aggiornamento dalla versione 0.49.6b1 alla 0.49.7 Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Fri 24 Aug 2007 - 15:32 ] | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.7.1![]() Aggiornamento dalla versione 0.49.7 alla 0.49.7.1 Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Fri 24 Aug 2007 - 15:32 ] | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.8![]() Aggiornamento dalla versione 0.49.7.1 alla 0.49.8 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.8.1![]() Aggiornamento dalla versione 0.49.8 alla 0.49.8.1 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | ArcConvert 0.49.9 Link winPenPack Aggiornamento dalla versione 0.49.6b1 alla 0.49.9 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.10![]() Aggiornamento dalla versione 0.49.9 alla 0.49.10 Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | ArcConvert 0.49.10a![]() Aggiornamento dalla versione 0.49.10 alla 0.49.10a Home: -Link- ![]() Direct Link: -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | ArcConvert 0.50![]() Aggiornamento dalla versione 0.49.10a alla 0.50 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: (dopo una conversione da .zip a .7z) ---------------------------------- Chiave aggiunta:3 ---------------------------------- HKLM\SOFTWARE\ACE Compression Software HKLM\SOFTWARE\ACE Compression Software\ActiveAce HKLM\SOFTWARE\ACE Compression Software\ActiveAce\2.0 ---------------------------------- Valore aggiunto:3 ---------------------------------- HKLM\SOFTWARE\ACE Compression Software\ActiveAce\2.0\Count: 0x00000000 HKLM\SOFTWARE\ACE Compression Software\ActiveAce\2.0\Name: 54 2D 4B 53 78 74 62 7A 72 79 63 64 37 76 79 73 37 44 72 63 63 7E 79 70 64 4B 42 63 72 79 63 72 4B 53 72 64 7C 63 78 67 4B 26 39 6D 7E 67 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 00 HKLM\SOFTWARE\ACE Compression Software\ActiveAce\2.0\Size: 0x0010F7A9 | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | ArcConvert 0.51 winPenPack link Aggiornamento dalla versione 0.50 alla 0.51 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato Test: non testato | ||
