Aggiornamento: Back4Sure Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.2.1 Link winPenPack Aggiornamento dalla versione 3.0.2 alla 3.2.1 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.3.0 Link winPenPack Aggiornamento dalla versione 3.2.1 alla 3.3.0 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare [ Edited Wed 07 Sep 2011 - 01:13 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.4.0 Link winPenPack Aggiornamento dalla versione 3.3.0 alla 3.4.0 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.5.0 Link winPenPack Aggiornamento dalla versione 3.4.0 alla 3.5.0 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.5.1 Link winPenPack Aggiornamento dalla versione 3.5.0 alla 3.5.1 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.5.2 Link winPenPack Aggiornamento dalla versione 3.5.1 alla 3.5.2 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.5.3 Link winPenPack Aggiornamento dalla versione 3.5.2 alla 3.5.3 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.5.4 Link winPenPack Aggiornamento dalla versione 3.5.3 alla 3.5.4 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.6.0 Link winPenPack Aggiornamento dalla versione 3.5.4 alla 3.6.0 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Back4Sure 3.7.0 Link winPenPack Aggiornamento dalla versione 3.6.0 alla 3.7.0 Home: -Link- Direct link: -Link- (32 bit) Direct link: -Link- (64 bit) Risultato test: niente da segnalare | ||
