Sponsored Links
Firefox 6.0 incompatible with JRE 6 Update 26
dropper
Wed 17 Aug 2011 - 16:57
Registered Member #39636
I've found that currently Firefox 6.0 is incompatible with JRE 6 Update 26. On the other hand, Firefox 6.0 is indeed compatible with Java SE 7, but Java SE 7 is not yet available on java.com. In fact, I've found that with Java SE 7.0 occur currently some issues, because it's impossible to use websites with Java applets.
Is it not far more useful, that the download of Firefox 6.0 will offered earliest with the completion of Java SE 7.0 for end users?
[ Edited Wed 17 Aug 2011 - 17:01 ]
dropper
Wed 17 Aug 2011 - 23:31
Meanwhile, I have found the cause of my problem. I have installed a VirtualBox by Oracle on my PC. In it, I've created a virtual machine with installed OS Windows XP Home SP3. In this VM I have installed Firefox 6.0 in conjunction with JRE 6 Update 26. After I have selected the website -Link- , I want to play the game Backgammon. Here will be started a Java applet, but this was not possible. Then I tested the same procedure (Firefox 6.0 + JRE 6 Update 26) on my real PC and it worked flawlessly. Consequently, my virtual machine was the cause of incompatibility between Firefox 6.0 and JRE 6 Update.
[ Edited Wed 17 Aug 2011 - 23:33 ]
Thu 18 Aug 2011 - 13:52
Hi dropper,
many thanks for your info/feedback! I've tried and tried to replicate your issue but i was not able to do it!
now every thing's clear
