X-Firefox 3.6.20 update thanks. |
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | Can I use X-Firefox 3.6.20 version update to 3.6.21 ? just ckick help--->check auto update to x-firefox ? and X-firefox 3.6.XX already stop update (now only x-firefox 6)? Thanks. | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi dlusera, every X-Firefox (both 3.5.x and 6.x) can be updated as it was an installed version. The only thing you must remember is that, after the update, Firefox MUST NOT be restarted, but you simply have to close it and re-run X-Firefox. That's all... Best Regards ZioZione | ||
