dito |
![]() ![]() ![]() Registered Member #11533 Joined: Sat 31 May 2008 - 09:32Posts: 200 | Ho testato il programma in oggetto ( -Link- ![]() Il programma serve per la conversione di video dal formato MKV al formato AVI (Xvid, DivX) in modo che i comuni lettori video da salotto li possano leggere. Il programma, secondo l'autore, dovrebbe essere portatile: "The program requires no installation. Just extract ZIP archive to any directory and double-click the file mkvtoavi.exe. The program is portable: it does not use system registry and all settings are stored in INI files in a directory with the program. Thanks to this program can be run from portable devices such as pendrives, removable drives." Allego il log di X-Regshot-1. Grazie mille. ![]() [ Edited Fri 04 Nov 2011 - 18:27 ] | ||
