ZSoft Uninstaller - Disinstallatore |
| dito |
![]() ![]() Registered Member #11533 Joined: Sat 31 May 2008 - 09:32Posts: 200 | Sembra che RevoUninstaller free (il miglior programma gratuito di disinstallazione) non sarà più aggiornato (esiste una versione superiore a pagamento). Ho cercato alternative open source senza trovarne di analoghe. Un programma free interessante (non esiste una versione superiore a pagamento), del quale esiste una versione portable, è ZSoft Uninstaller. Nome del software: ZSoft Uninstaller Direct Link al download: -Link- (portable, secondo gli autori)Dimensione File: 1,09 MB (compresso) Nome autore: ZSoft Software Sito Web Autore: -Link- ![]() Descrizione: ZSoft Uninstaller is the better and easier way to uninstall programs on your computer. ZSoft Uninstaller can be used as a Add/Remove applet replacement, but not only that, it can also: Analyze an installation so it can be completely uninstalled (also supports reboots of the computer as the process is split into two: Before and after the installation) Search for leftovers after uninstalling a program Cleanup in the programs starting on your computer at startup Find and delete temporary files Find and delete empty folders Delete entries from programs that are no longer installed Hide Windows Updates Hide entries from the list that you are never going to uninstall (drivers etc.) making the list smaller and therefore easier to manage. Show more information than available though add/remove Automatically find entries from programs that are most likely already uninstalled Automatically find entries that are considered "crap-ware" (Off course) search the list of installed software Portable tips how-to: secondo l'autore il software è portatile Versione: ZSoft Uninstaller portable 2.5 Licenza: freeware Screenshot: -Link- ![]() Brevi guide: -Link- e -Link- ![]() edit: scusate, mi sono accorto subito dopo dell'esistenza di un vecchio post relativo al programma in oggetto -Link- , anche se il rilascio di una versione portable potrebbe cambiare le prospettive; potete cancellare.Licenza: freeware (Permission is granted to use this software for non-commercial purpose only) [ Edited Sat 28 Apr 2012 - 07:14 ] | ||
