Icon disappeared |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I have installed on my PC Adobe Reader 10.1.3 and I have set up it as the default program for opening of *.pdf files. Besides I have integrated the portable program PDF-XChange Viewer in the winPenPackNet menu and there determined, that it should be the default program for opening *.PDF files. All works fine, i.e. if the winPenPackNet menu isn't started, a *.pdf file will opened with the Adobe Reader 10.1.3 and if the winPenPackNet menu is started, then a *pdf File will opened with the PDF-XChange Viewer. If the winPenPackNet menu is started, then in the Windows Explorer will appeared the appropriate icon of the PDF-XChange Viewer regarding *.pdf files. But if I have closed the winPenPackNet menu, then in the Windows Explorer not appeared the icon of the Adobe Reader 10.1.3 regarding *.pdf files. How can I solve this problem? [ Edited Fri 20 Jul 2012 - 12:23 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | In the meantime I have solved my problem. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | glad to read this! How did You solved? (I'm not just curious... ...is for a complete info to other users ) [ Edited Fri 20 Jul 2012 - 15:45 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I will explain the solution for the OS WinXP SP3, which is used by myself.
[ Edited Fri 20 Jul 2012 - 17:12 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Many thanks dropper! | ||
